Stuck in Bfe west texas with a rough running truck - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 2 Old 04-22-2013, 08:43 PM Thread Starter
I must be jinxed in this area of Tx. Anyways, yesterday evening about 30mi out of Van Horn, Tx my truck ('99 7.3, 200k on engine, manual trans) lost power and started running rough. Got towed back to Van Horn and figured out the likely culprit was the uvc harness. Limped into a shop this morning and found the 4 injector wires plus the common looked like all the insulation had been chewed off and just the bare wires were exposed. Pulled them apart and the truck instantly ran better. Then as it was sitting there it pissed coolant all over. So after a new water pump and some liquid tape on the wires, we were on our way and the truck ran great. About 40 miles down the road, I lost power and it started running rough again. Checked the wires and made sure they were separated, it ran better but was still missing and low on power.
Finally was able to limp it into a rest area and I said screw it and pulled the driver side valve cover to check the plug. Well it has previously been fixed with a zip tie. So, frustrated and out of ideas, I put it back together and it seemed to run okay and we made it the 25mi into Ft. Stockton Tx. Now it seems to be running okay, maybe slightly down on power.
Things I noted when it started running rough:
Egts started to sky rocket, 950 plus at 50mph and losing speed.
Seems to only happen after the engine builds some heat.
Comes and goes.
I was given the # to "a guy who knows these engines" that is local, but if he isnt able to scan and monitor the engine while its running, Im not even messing with him. Theres also a Ford dealer, so maybe I'll just have them scan and diagnose it. Im just trying to figure out where to go from here and what to suspect. Im not 100% confident its not the uvc harness or the wiring since its chewed up.
HillbillyDeluxe99 is offline
post #2 of 2 Old 04-23-2013, 08:30 PM Thread Starter
Figure I should update this. Figured out the issue earlier today. After the truck ran great all morning, we got 27mi outside of Ozona Tx before it started throwing a fit again. This time I called Diesel Innovations so I could talk to David to see if he had any insight. He was busy but one of his guys took the time to talk with me. He suggested the CPS, and out of ideas, I limped it to Ozona Tx and found a Napa. Swapped it out and the truck wouldnt even start afterwards. As a last ditch effort, I disconnected the Edge Evolution tuner (I only use it for the monitor) where it connects to the CPS. The truck fired right up and ran perfect. I knew right then I fixed the problem. Made it all the way back to Houston running 75-80 most of the way.
So if you're having problems with your truck running bad and its got an Edge product on it, disconnect that piece of junk and throw it in the trash. I'll be ordering up some real gauges here real soon.
