Crank, no start - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 12 Old 04-12-2013, 03:00 PM Thread Starter
Crank, no start
Okay so I drove my truck to the gym, all fine. Left the gym the truck fired right up. Went to get food and I come out and it won't start. It cranks but just won't turn over. FICM good. Batts good. The truck is facing uphill and I think that had something to do with it because this happened once before. The last time about 2 weeks ago it was warm I had driven it a while and I parked somewhere facing downhill. Came out and it would just crank. That time it just worked itself out.
Powerstokin is offline
post #2 of 12 Old 04-12-2013, 03:17 PM Thread Starter
okay after many tries it finally fired. it cranked for about 20 secs then the oil pressure gauge started rising. any know what this could be?
post #3 of 12 Old 04-12-2013, 03:23 PM
How many miles?
I read somewhere that if your low pressure oil pump is weak that it generates it's first symptoms when parked uphill. One dealer puts the truck on level ground, then jacks up the back and adds three qt oil as a test. If that gets it to start, where it wouldn't before, then there is an issue with the LPOP.
prheitz is offline
post #4 of 12 Old 04-12-2013, 03:50 PM Thread Starter
Originally Posted by prheitz View Post
How many miles?
uh oh. it has 61000 miles
post #5 of 12 Old 04-12-2013, 05:40 PM
As long as you changed oil regularly, it is probably something else.
prheitz is offline
post #6 of 12 Old 04-12-2013, 06:03 PM
As long as you changed oil regularly, it is probably something else, but please keep us posted.
prheitz is offline
post #7 of 12 Old 04-13-2013, 03:13 PM Thread Starter
starting to sound like LPOP. drove to the farm today shut er off. barely came back on a little later
post #8 of 12 Old 04-13-2013, 05:51 PM
crank no start
im having the same prob now with my 2007 f250 went into the store and came out and she wouldnt start i have no idea what it could be i just replaced all 8 injectors the ficm , glow plugs and glow plug module anyone have any ideas what it could be this time
amobe04 is offline
post #9 of 12 Old 04-14-2013, 04:53 PM
Wouldn't that simulate being parked downhill as opposed to uphill? If the back is jacked up, its going to be higher than the front.
When parked uphill, the front is higher than the back...Is this just more than one way to look at it or am I missing something? I think I may be having this problem with my truck.
Pipewrench is offline
post #10 of 12 Old 04-14-2013, 05:10 PM
onealmx11's Avatar
Quoted: 164 Post(s)
No diesel tech here, but maybe cam position sensor. Ant dtc's?
onealmx11 is offline
