Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 01-20-2008, 08:55 AM
inflorida inflorida is offline
06 won't start
I have an 06 250SD w/19,800 miles. I made a spare key for my truck, but not from Ford. (I forgot that I needed to get it from Ford). This morning I went out to start the truck using the spare key and the truck would not start. It acted like the batteries were dead or dying. The temp this morning was 27 to 29 degrees with a 15 to 20mph North wind. I tried my factory key after I tried the spare but now the truck won't even click. The radio however plays loud like the batterries are fine. ANY ideas?
Old 01-20-2008, 09:13 AM
SuperDutyPSD6L SuperDutyPSD6L is offline
charge the batteries
Old 01-20-2008, 09:34 AM
strokethis69 strokethis69 is offline
check to see if your posts are nice and tight if all 4 are not tight it will not turn over fast enough to start but all lights will still work
Old 01-20-2008, 09:37 AM
mschn99 mschn99 is offline
Banished
it has nothing to do with the key.....ford didnt start using PATS keys on superduties till 08.....only excursions had them....
It definately is a battery/starter or wiring problem as stated above....having enough juice to crank a diesel over is very important...and weak batteries or loose connections will cause a no start....
Old 01-20-2008, 10:02 AM
Thanks a bunch for the quick responses! I checked the battery terminals on both batteries and thay are tight. I had suffered from that problem on another vehicle before. I have only had the truck since Sept 06 and find it hard to beleive the batteries are that weak. I drove the truck yesterday and it started and ran fine. I have noticed several times in the past six months or so that the truck will act like the batteries are not that strong when I go out and start it up, but this has occured when the weather was warm also. Could the batteries be weak/bad and with the cold weather (for Florida) I just need to get new ones? My 01 250 SD didn't give me this much problem in the 5yrs I had it.
Old 01-20-2008, 10:04 AM
Banished
it very well could be the batteries......they should be charged and tested. Just because they have the voltage to run the radio doesnt mean they have enough cold cranking amps to actually start the truck....
also make sure to have your Altenator tested because an under or over charging altenator can take batteries out. One bad battery could cause the other one to fail as well. If one of the batteries has a bad cell it could be causing your whole problem...
Old 01-20-2008, 10:20 AM
I'll take the batteries out, get them checked, and let ya'll know where I stand.
Old 01-20-2008, 10:39 AM
Diesel Freak Diesel Freak is offline
Rice Hunter
WOW! I bought mine in OCT. '06 and would hate to think I needed batteries already.
Check your warranty on factory batteries also
Old 07-02-2008, 09:46 AM
Took the truck to FORD and they replaced the dead battery. Truck fired right up. Thanks to everyone that gave their two cents.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
