| 911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only |
no heat!!!
2006 f350 ming ranch dually. Digitl climate control. Wont blow out any heat!!!! please help
no heat
so when i crank the heat on, just blows out air. no heat. the vaccuum actuators are working under the dash. but no hot air. ay ideas?
Coolant level ok?
i just had oil coolers and head gaskets done recently
Ok, is the coolant level ok though? Might have dropped a little since repair if there was air in the system.
i have a vacuum line that came undone or something on mine last winter. look on your passenger side under the hood. i believe thats where mine was at when a buddy that works for ford look at it
That gray hose will only keep the vents from switching properly. It shouldn't affect the heat itself.
What about the vacuum line that goes to the shut off valve on the heater hose? On top of the passenger side valve cover.
I had the same problem after deleting my EGR and coolers. Turns out I had a MEAN air bubble in the lines. I got it up to full operating temp, turned the heater on full blast and went under the hood and pinched and shook the crap out of the radiator hose next to the driver side battery. I could watch it burp the bubbles into the reservoir.
