Help! Just died on the side of the road! - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 04-22-2012, 08:30 AM
Taking an exit off the highway and she stalled and will not restart. Plenty of fuel, oil, battery and Fi voltage.
Likely the fuel pump? Anything I can check sitting here?
Old 04-22-2012, 08:43 AM
Well, I got her started and she idles fine, but when I press the accelerator nothing happens. No response at all.
Old 04-22-2012, 09:07 AM
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
Do you have any way to check PID's?
Old 04-22-2012, 09:20 AM
Ther are no engine codes. I let her idle for 20 minutes and then tried to start her again, no luck. Rough when trying to start her again and would not start. Pulled the accelerator assembly off, nothing I can do there.
Old 04-22-2012, 09:28 AM
I don't hear the fuel pump running either. There is a lot of background noise but I should hear it.
Old 04-22-2012, 10:00 AM
TPS - Throttle Position Sensor
Quick search, anything in here help?
Old 04-22-2012, 10:04 AM
Hmmmm. Checked the fp fuse and it looked fine, but apparently wasn't. Changes the fuse and she started right up.
Hmmm. Hopefully it will get me home but needs further investigation... Any suggestions as to why that would happen?
Old 08-23-2012, 08:55 AM
Just an FYI, it was a dirty EGR valve that causes limp mode and no starts.
