bad fuel - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 03-17-2012, 01:34 PM
bad fuel
long story short I have gotten bad diesel with water in it. I have a 1/4 tank of the ****, my truck now wont start. Cranking at 150rpms, not firing. How can i get it started?
Old 03-17-2012, 02:00 PM
Drain the tank, change your water separator and filters and re-fill with good fuel and then purge the air out of the fuel lines and crank till it starts... What year is it? If it's a 6.0 just cycle the key on for 30 seconds then back off several times and the electric pump should fill the fuel bowls and prime the lines with good fuel once you've gotten the junk out of the tank... dry firing heui injectors can mushroom the tips and damage them so try to get as much air out before you start cranking as possible.
