help!!! - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 03-06-2012, 05:17 AM
help!!!
i have '04 f250 6.0. recenntly i have run out off fuel. put fuel in with my spare tank. tried to start, it turned but wouldn't start. then the battery went weak. tried to jump the batteries for an hour, no luck. it still sound like dead batteries. went and bought 2 new batteries, but still like dead batteries. noticed one thing, when i turn the key on and wait for glow plugs indicator to goes off before start, but it wouln't goes off. try to start anyway but it sounds like dead batteries. but if i turn on the key and let it sit for about 15 sec. when the pump noise (like fuel pump) in the engine compartment goes off, then i try to start, the engine turn very strong, but wouldn't start. please help!
Old 03-07-2012, 06:52 AM
Have you checked your fuel filters? I would check/change both. One is under the hood , next to your oil filter and the other is under the drivers side of the truck on the inner side of the frame rail. You may have pulled up some sediment from your tank and plugged them.
Ps. Use motorcraft filters
