| 911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only |
Dead on the side of the road 911
2000 F250 just died like key was shut off . 60 psi fuel pressure , changed CPS, icp cranking 120 psi , unplugged ICP pressure at 2118psi. no codes , other than the IDM code, 1,3, 8 high to low side open. These codes I,ve had since summer, changed out IDM still same codes. still no start? what next?
I have smoke coming out the tailpipe.????????????????????????
Could it be the Cam sensor? There was a recall on these awhile back. Some trucks would just die and you had to replace the sensor on the motor. 10 min job. Not saying thats your problem though.
Oops didn't see your second post... Well I think that rules that out.
Thanks anyways.
bumpppppppppppppppppppppppppppppppppp
took out my F5 chip , nut on back of IPR tight,still no start
need to know ipr pressure while cranking engine over??
About 120 to 300 psi , with Icp unplugged its 2118psi.
Could there be a fuse? The IDM relay? Give the fusebox a good going-over maybe....
Fuel OK? Drain some out out and have a look, did you just fuel-up or anything? Go Up or Down a really steep hill? (coulda "sucked-up" some water?) UVCH plugs been looked at lately? Could something have come loose? What kind of scanner do you have? Can you "Buzz Test"? Been raining a lot? Could the IDM have gotten wet up there? Any chance the new CPS was defective? On a 2000 you should see Tach Movement... Try "rapping" on the IPR with a screwdriver handle or something. Engine oil level where it should be? Last edited by NoRalPh; 01-22-2012 at 11:39 AM. |
