Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 09-07-2007, 04:54 PM
cctowing450 cctowing450 is offline
Flasher Relay Location
My turn signals do not work at all. I was told it was the flasher relay but I can't seem to find where it is located. 2000 Ford F450 powerstroke 7.3L. It would be great if someone could help.
Old 09-07-2007, 04:57 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
I will go get my owners manual right now and see if I can find it for you. In the meantime someone might get you the answer anyway
Old 09-07-2007, 04:58 PM
sawyer1 sawyer1 is offline
theres a (blue square realy) under dash up by radio bout 10$ dollars to fix it its kinda a pain to get to from under the dash. This might be the one my buddy had same problem and this fixed it hopfully its your same prob.
Old 09-07-2007, 05:03 PM
Yeah I can't help you as the manual doesn't show that relay
Old 09-07-2007, 05:05 PM
pipelayerjdh pipelayerjdh is offline
MINI-MOD
The relay holder is tucked way up under the instrument panel just to the right of the steering column. It has two large relays and two small ones, I think.
