Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 09-07-2007, 02:29 PM
MAVERICK STROKER MAVERICK STROKER is offline
LOST CYL'S 2 4 6 8 NEED HELP
96 PSD , standard tranny . valve cover wiring harness was burnt on hot side of # 2 injector and burnt the male plug from engine harness. replaced the harness end with kit from ford, replaced both inside harnesses and valve cover gasket , still dont have cyl's 2 ,4 ,6 , & 8 . they work under the buzz test but with engine running there is no difference in roughness by unplugging one or both connectors on 2,4,6,8 . checked injectors for ohms test and all passed, checked wiring harness and its good. wandering if the control box for the injectors can be bad and still run cyl's 1,3,5,7 ? codes now are P0606 , P1111 , CYL BALANCE TEST SHOWS 2,4,6,8, BAD? NEED HELP BEFORE I PULL MY HAIR OUT...... THANKS
JEFF
Old 09-07-2007, 02:51 PM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
what does injector buzz test do
Old 09-07-2007, 06:00 PM
stroker350 stroker350 is offline
Maverick, Could it have blown one of your fuses when your wires shorted out?
Hope you can find out what happened quick, as my '01 fried the wires on the drivers side 3 weeks ago. Sounded terrible and very sick running on 4 cylinders!
Old 09-07-2007, 06:02 PM
pipelayerjdh pipelayerjdh is offline
MINI-MOD
check the rest of the harness for damage.
Old 09-10-2007, 12:40 PM
squeeks squeeks is offline
almost sounds to me like your idm is burned up
Old 09-10-2007, 12:51 PM
sldghamr sldghamr is offline
i have a 96er myself. my harness went out also about a year and half ago. the mechanic just replace the harness and didn't have any problems since. i don't have any suggestions for you.
