Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 09-03-2007, 04:16 PM
brentp1 brentp1 is offline
Overheating while idling
I have an 05' 250 w/ the 6.0. I was driving back from Atlanta today and when I pulled off at a McDonalds for a lunch break My truck overheated. I cut it off and let it cool down. Started it back up and drove home and everything was fine. When I pulled in the driveway I let it sit again for a minute, overheated again. Let it cool off again, Started looking the engine over and my coolant resivior is dry. I can't find where anything is leaking. Looking on the forum I saw where someone used a term called "puking" where the overflow would let out fluid if the pressure got to high. If this is my problem how do I fix it or should I be looking somewhere else?
Old 09-03-2007, 04:30 PM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
is the coolant level low , if not maybe a clutch fan problem , if it only does it idling
Old 09-03-2007, 05:23 PM
Yes, The coolant is low. I just put 2 gals in. What could cause the coolant loss without a leak?
Old 09-04-2007, 03:57 AM
you more than likely have an egr cooler going out
Old 09-04-2007, 01:34 PM
Thank's, I'll look into that.
