Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 08-28-2007, 10:08 AM
tyb02powerstroke tyb02powerstroke is offline
02 PSD 7.3 problem....help!
I have replaced cps twice. Checked for codes and had a pcm circuit fault. Replaced PCM. Truck will start and run fine, however when the truck reaches operating temp and you turn the truck off, it will NOT start until it cools down! I cannot figure this out! Please, any suggestions?
Old 08-28-2007, 10:12 AM
WEWILLE WEWILLE is offline
Does it crank, or crank very slow it could be a starter.
Old 08-28-2007, 10:19 AM
SCUFFY828 SCUFFY828 is offline
FORD MASTER DIESEL TECH
you said it hard a pcm circuit fault , which code was that and is it giving you a code now, very seldom if at all does the pcm go bad
It cranks strong. Nothing wrong with starter.
Old 08-28-2007, 10:20 AM
i dont remember the exact code, though I do remember looking at the scanner when it said PCM Circuit Fault.
Old 08-28-2007, 10:26 AM
I would scan it again, and see what codes you get.
Old 11-29-2007, 06:00 PM
silver eagle silver eagle is offline
WHERE YOU HAVE CHANGED THE CRANK SENSOR TWICE YOU MAY WANT TO INSPECT THE CONNECTOR VERY CLOSELY. HAVE SEEN ALOT OF CONNECTION PROBLEMS INSIDE OF THE CONNECTOR HARD SHELL. THE WIRE ( OR WIRES ) WILL LOOSE CONNECTION INSIDE AT THE TERMINAL END. WITH MORE HEAT AFTER ENGINE SHUTDOWN WIRE WILL LOOSE CONNECTION AT TERMINAL END. AFTER COOLDOWN CONNECTION WILL BE RESTORED. WIRE AND TERMINAL END NEEDS TO BE REMOVED FROM HARDSHELL TO FIND THIS PROBLEM. EVEN IF CRANK SENSOR CONNECTION IS NOT THE CULPRIT ANY OTHER FUEL RELATED SENSOR CONNECTION COULD BE AT FAULT GIVEN THE SYMPTOMS YOU GAVE. GOOD LUCK!
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
