HELP!!! FUEL PROBLEM - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 10-03-2011, 12:23 PM
WJC WJC is offline
I have a 1997 7.3 powerstroke and I am having a fuel problem.
When the engine is started fuel starts pumping out from what appears to be on top of the manifold. It is in a Ford van so getting to it is not easy.
Does anybody have an idea what it could be? How hard might it be to fix? I have a mechanical background but am unfamilar with diesel engines.
Here is a pic of the area I am talking about. The Blue arrow points to the area fuel is spitting out from.
Thanks for any help.
Old 10-03-2011, 06:35 PM
Hmm...
This is most likely one of the hoses under the fuel/water separator that has sprung a leak. Or a bad washer on the banjo fitting under the turbo pedestal.
Pretty involved on a van according to Alldata, first instruction is to remove turbo. Hopefully someone chimes in here with and alternate theory.
I would probably replace the pump, hoses, clamps, and banjo washers. You'll also have to replace the turbo pedestal o-rings if you remove the turbo.
You're looking about $150 in parts and about 4 hours of your time.
What is the exact year and model? Did you mean '97 E-350?
Old 10-03-2011, 07:04 PM
WJC WJC is offline
Yes, 1997. sorry about the typo. Correct, it is in a E-350.
Old 10-03-2011, 07:12 PM
this will.....
Help.
Turbo removal and Installation:
turbo.pdf
Fuel/Water Sep. removal and Installation
Fuel_Water_Sep.pdf
When you see all the little hoses in there, you're gonna want to smack an engineer.
Hope this helps.
Old 10-03-2011, 07:19 PM
WJC WJC is offline
Thank You!!! I will check them out.
I deal with engineers on a regular basis...and I want to smack most of them to.
