truck has no power pulling off from stop - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 7 Old 09-21-2011, 08:28 PM Thread Starter
Last week i was sitting at a red light and all of a sudden i had now power when i gave it fuel. I checked the filter that had 3000 miles on it and it was trashed. changed both of them and began draining lots of water and trash out of the main filter housing. Added seafoam and Clear diesel to tank. Any other suggestions. Thanks
registerfarms is offline
post #2 of 7 Old 09-21-2011, 08:39 PM Thread Starter
Another thing. The truck starts up and idles fine. Can baby it and get the rpms up and it will take off, but as soon as you let off on the fuel you haft to baby back the rpms up. Getting lots of black smoke. Any help would be great. truck is an 2004 f250 6.0 Thanks
post #3 of 7 Old 09-22-2011, 05:20 PM Thread Starter
anyone with any suggestions?
post #4 of 7 Old 09-23-2011, 11:50 AM
Powerstroke Techie
Sounds like a stuck open EGR valve. I would take it out and see if a chunk of carbon has it held open.
MotorCrafter3208 is offline
post #5 of 7 Old 09-23-2011, 03:24 PM Thread Starter
Thanks. ill check that
post #6 of 7 Old 09-23-2011, 05:43 PM Thread Starter
Well i checked the EGR valve and it was stucked closed. Cleaned it with break cleaner and worked it back and forth until it was closing on its own. Put it back in truck and all problems were solved. truck runs great again. Its only been 12000 miles since I did the replaced the EGR cooler and Oil cooler. I cleaned it then. I guess the bad fuel might of helped it stick shut. Thanks for all your help.
post #7 of 7 Old 09-23-2011, 06:14 PM
Powerstroke Techie
That's awesome! Glad i could help.
