Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 08-08-2007, 08:14 AM
daveexplorer daveexplorer is offline
Code trouble
I have a code of p0478 and p0470 can any tell me what this could be My SEL is on. It is a 2000 f350
thanks
Old 08-08-2007, 08:29 AM
jfines@cox.net jfines@cox.net is offline
p0478-Exhaust Back Pressure
p0470-Exhaust Pressure Sensor Malfuction
At least according to google
Old 08-08-2007, 08:46 AM
Do you know what the fix would be????
Old 08-08-2007, 08:53 AM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
probably need to replace ebp sensor and r&r tube from right manifold to sensor and clean it out , that will fix it
It sounds like the exhaust back pressure sensor has malfunctioned. Could be wiring.
also check your EBPV, the valve at the bottom of your turbo. See if it is stuck.
The p0478 is for High pressure. If your valve is stuck, you would notice a power loss, and the exhaust would be louder.
Old 08-14-2007, 05:11 PM
TruckTrooper TruckTrooper is offline
P0478 Exhaust pressure control valve high input Plugged sensor line, stuck butterfly, restricted exhaust
P0470 Exhaust back pressure sensor circuit malfunction Biased sensor, open signal return
