| 911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only |
1995 f350 ICP sensor
Where is the ICP Sensor located on a 1995 f350? need to change asap. if possible could you show a picture of location. thank you in advance
THANK YOU.....
I just checked and found it. But there isn't any oil leaking on or around it which is what alot of people have said to look for with a bad icp. Its look relativity clean not what i would expect to see when looking for a bad part. But i guess i will try it not much to loose at this point.
Did you try the cps? Much cheaper if you are going to start buying parts and trying
i was going to try the cps but when i had the codes pulled on the truck it came up as being the icp.
