Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 07-30-2007, 12:56 PM
ranorthjr ranorthjr is offline
power stroke 6.0 problem
I have a 2003 6.0 ford power stroke. When first starting in morning there is no power and when you accelerate the engine stalls, almost caused an accident.
Old 07-30-2007, 01:02 PM
duramaxslayer duramaxslayer is offline
Welcome to the org!
Im sure a tech will be along very soon and have a good answer for you!
Old 07-30-2007, 01:05 PM
mschn99 mschn99 is offline
Sounds to me like you need to take it into the dealer and have them put the latest programming in the truck, sounds like an injector or two sticking to me and the programming will clear that up within a day....
Old 07-30-2007, 01:32 PM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
i agree with marc
Old 07-30-2007, 01:53 PM
rednek01 rednek01 is offline
Send a message via AIM to rednek01 Send a message via Yahoo to rednek01
do they charge to do this? My truck still has the program that causes the injectors to buzz after shutdown for a few monents. Should I have them update it mine as well? Sorry to hijack a little bit
Old 07-30-2007, 01:56 PM
If you are still under the 5/100 warranty they wont charge you IF you come in with a concern they need to reprogram it to fix the concern...
If you are out of warranty or just want it done...it will cost you probably 1 hour of labor to have done at most places....
Old 07-30-2007, 02:08 PM
ok but do I really need the updated program? What all does it change?
Old 07-30-2007, 02:11 PM
the biggest thing is it cures the muss, lack of power, and or white smoke on cold starts. It also eliminates the injector buzz and does it a different way, so your truck wont talk back anymore. Other than that....no...its nothing that does anything else for you, so if your not concerned with the above (or havnt had it happen) then its not worth doing...
