Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 07-19-2007, 08:15 PM
oafydude28 oafydude28 is offline
Send a message via Yahoo to oafydude28
Unhappy tank strap broke help
So i was at a friends house removing the muffler on under my truck. When i went to slide over and i bumped into something so i turn around and its my fuel tank hanging there by the back strap the front one was broke. I talk to my brother who is a gm macanic and he doesn't think that ford made a fuel tank that is just a long steel box. my truck is a used 2006 f-350 crew cab short box. so i have two questions does ford make that type of tank? my brother says that he has only seen molded tanks on the ones that he has seen. The most fuel i have put in it was 39 gallons with the low fuel light just turning on. And second has any one had a strap break. I only have 53000 miles on this truck and i think a fuel tank strap should last longer than that. sorry for the novel post. Thanx
And the truck sounds great now.
Old 07-19-2007, 09:52 PM
bump
Old 07-19-2007, 09:58 PM
Blue01F250 Blue01F250 is offline
Tournaments Won: 1
mines molded kinda - but is like a big rectangle with rounded corners....
I would get ya a picture, but its dark
Old 07-19-2007, 10:02 PM
2005F250 2005F250 is offline
Probably a bad strap. Call aero fuel tanks or transflow to get a replacement.
Old 07-19-2007, 10:04 PM
i took a secound look and the tank is 5 to 6 feet long about a foot wide and has a slight angle on the front. im assuming thats so it doesn't catch on anything. But the stap has only sight surface rust. it snapped right on the first right angle bend next to the out side hanger bolt. just seems odd.
Old 07-19-2007, 10:09 PM
i have a extended warranty but it has a $100 deductible. should i have them replace it with another factory strap or would an after market be stronger. also sould i replace both because i think i drove 120 miles before i saw it today? Thatx for the help you guys ROCK!!!
Old 07-20-2007, 05:20 AM
bump.............
Old 07-20-2007, 05:39 AM
WEWILLE WEWILLE is offline
ready for spring
You could probably get an original for pretty cheap and throw it in yourself. The strap is way less then 100 bucks i'd imagine so i wouldnt go in for warrenty. That sounds really wierd though, because usually you dont see straps breaking on newer vehicles.
Old 07-20-2007, 06:31 AM
Exclamation
Well i just stopped in at a ford dealership and they said that the tank was aftermarket. i just bought the truck about a month ago. I have no idea were to go to get it fixed. It looks like its just angle iron but i dount know were i would pick that up or the right way to bend it so it doen't break.
i live in Eden Prairie,MN
Old 07-20-2007, 01:25 PM
bump bump......
