Leaking fluid and chattering transmission - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 02-24-2011, 07:32 PM
My truck is hemorrhaging clear fluid with a very very slight speckling of pink. Today, for the past several hours, my truck has been making a very present chattering or knocking like something spinning in a not-healthy way.
I don't know how to describe it, but if you listen to the sound your truck makes when it first shifts into overdrive and let it coast, it's very much like that but at ALL speeds!
I can't tell where the fluid is coming from but it has coated my driver side tires and is on my front driver side wheel swing-arm.
It's a 6.4l 4x4 2009
Also, the vacuum above the exterior fuse box has been buzzing much more frequently.
Old 02-28-2011, 03:53 AM
Check the degas bottle to see if it is puking, also check the hydroboost lines for leaking.
