7.3 Starts when cold dies when warm - Ford Powerstroke Diesel Forum
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
post #1 of 12 Old 05-31-2010, 01:40 AM Thread Starter
alrocky's Avatar
Angry 7.3 Starts when cold dies when warm
I am in the "land down under " Australia , I have a 7.3 F250. I was driving along then vehicle shut down like ran out of fuel.
Towed to mechanical garage, have replaced CAP sensor, HPOP sensor, oil temp sensor, new IPR kit, the engine coolant sensor appears to be okay when checked, checked IDM, checked computer, replaced air filter, fuel filter, changed oil and filter, checked relays and all seem to be okay. Fuel pressure is reading 60psi when running and when it shuts down.
The vehicle starts when cold, then when it warms up (about 15to 20 minutes it shuts down.
Can anyone give me any other suggestions, the mechanic is scratching his head in bewilderment.
**** Yeah ha!!! Release the pidgeons, finally back on the road after 4 weeks in the garage. The problem was the solnoid on the IPR, I have the vehicle back with spare bits that were replaced that were fine, just gald to be back on the road. Thanks for the help from everyone.
alrocky is offline
post #2 of 12 Old 05-31-2010, 03:21 AM
Shaking the Bush Boss
CHUCK's Avatar
bump up for ya....
Chuck
CHUCK is offline
post #3 of 12 Old 05-31-2010, 03:25 AM
Other vehicle is an F250
Hank's Avatar
No codes? I'd hook it up to a scanner cold and wait for the shut down and see if anything shows up?
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #4 of 12 Old 05-31-2010, 11:41 AM Thread Starter
alrocky's Avatar
Tried the scanner, showed some codes, cleared them, restarted engine, when it shut down there were no codes.
alrocky is offline
post #5 of 12 Old 06-01-2010, 02:12 AM
greasltn's Avatar
What were the codes that you cleared?
-John
Rudy's Diesel Performance - 919-383-9300 - Diesel Tech
greasltn is offline
post #6 of 12 Old 06-16-2010, 06:34 AM
Articcatzl440's Avatar
its could be a cam sensor. i had a 99 and i had the camper and boat behind it and leaving the driveway it just died turned out to be a cam sensor.
2005 F350 CC LB 6.0 Lariat,
Goodyear Wrangler Silent Armor Tires,
RCD EGR Delete,
New oil cooler 65,500,
Cat ELC Coolant,
Updated turbo drain tube,
2004 Excursion 6.0 Eddie Bauer,
Cooper Discoverer AT3,
FireStone Rideright air helper springs,
EGR delete,
ARP Studs,
1994.5 F350 CC LB Powerstroke
305,000 and counting
ZF5 Speed
Cat ELC Coolant
6637 intake
solid flywheel
Rose Wood Stage 1.5
Diamond Eye 4 inch
Isspro Gauges
BFG 33/12.5/16.5
Articcatzl440 is offline
post #7 of 12 Old 06-17-2010, 02:05 AM Thread Starter
alrocky's Avatar
The code was the oil temp sensor, mechanic has replaced it, still no go.
The cam sensor was the first part replaced and didn't help.
The truck went to the auto electrician last week and the computer was checked and working. They are still going through all the systems and will let me or the mechanic know whats is up, they seem to believe it has something to do with power between ignition and computer.
alrocky is offline
post #8 of 12 Old 06-17-2010, 02:24 AM
Hank's Avatar
Do you have a remote start installed? I went back and read your first post. When I remote start mine and then don't drive it, it will shut down in 15-20 minutes. Just a thot I had?
Hank is offline
post #9 of 12 Old 06-17-2010, 03:01 AM Thread Starter
alrocky's Avatar
No I don't believe there is, as I have no device for that . To make sure I'll have the auto electrician check, there should be a electronic hand held device for that ?????
alrocky is offline
post #10 of 12 Old 06-17-2010, 04:46 AM
Hank's Avatar
Mine (installed before I bought the truck) has a black box hanging in the wires behind the panel under the steering wheel. I control mine with a key fob. I suggested it because you just never know? Good luck sir.
Hank is offline
