Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 04-07-2007, 02:22 PM
997.3PSD 997.3PSD is offline
Please Help
I noticed this a day or two ago but i have a coolant leak from the front of my engine right behind the crankshaft pulley it seems. It started out very slow on a hot day and i thought nothing of it at the time but today i parked my truck and i have fluid pouring out of it like a sieve. It looks to be coming out right behind the lowest pulley (crankshaft?) and i have no idea what it is at the moment and i can't get the truck to a shop until monday. Any help will be greatly appreciated.
It slows down to a drip after a while but after running the truck it comes puring out pretty bad.
Old 04-07-2007, 03:47 PM
jojo1928 jojo1928 is offline
Check the weep hole on the bottom of the water pump. Mine did the same thing and i had to replace it ( the water pump not the weep hole in on the bottom )
Old 04-07-2007, 04:29 PM
I'm hoping it's just the pump. Right behind the crankshaft pulley is where it is coming out like between the pan and the crankshaft. Where the separation in the front is.
Old 04-07-2007, 07:18 PM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
It is most likely the water pump going bad. You notice where it is leaking because it is leaking down thanks to our friend gravity.
Old 04-07-2007, 07:25 PM
rottys rottys is offline
i agree water pump also before you drive it to much, make sure you check that the fan shaft is not loose my buddys was when the water pump started to leak.that could get ugly realy fast
Old 04-08-2007, 10:59 AM
Thanks a lot guys for all the help. I pm'd scruffy (diesel tech) and he said the same thing about it being the water pump. It's going to the shop on tuesday. Again thanks for all the help. She's up to 145,000 miles with only a new CPS and tranny rebuild after many years of towing farm animals and such. I'm very very happy with her.
Thank You.
Shane/997.3PSD
Old 04-14-2007, 11:51 PM
matt morton matt morton is offline
why not do it yourself and save a chunk of $$$$?its pretty easy to change.
Old 04-15-2007, 05:11 AM
I aggree as well. DIY the water pump. Pretty simple job, the worst thing about doing it is getting to the pump. If you have questions about the job ask us. But if you decide to do it yourself then while your getting the parts and gallons of coolant at the part store pick up a chiltons or a haynes repair manual. Just follow the steps in the repair manual and in about 3 hours you should be done.
By the way you will need the fan clutch wrench in order to get the fan off the water pump prior to removal.
Old 04-15-2007, 05:28 AM
BOBAGANOOSH BOBAGANOOSH is offline
I Have R+r'd My Water Pump Twice It Is A Really Easy Procedure If You Dont Mind Getting A Little Dirty Just Drain Her Take Her Belt Off And Go I Would Recommend Diy Because The More Time You Spend Under The Hood Of Your 7.3 The More Youll Understand Her Subtle Beauty I Think Im In Love W/ Mine (is There A Rehab Clinic For Powerstroke Addiction And What Stars Will I See When Im There)lol
Old 04-15-2007, 05:33 AM
I don't know but I am starting a group therapy for this problem.
