Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 11-05-2009, 06:30 PM
SQUID135 SQUID135 is offline
IM GIVING UP
Maybe you guys can help out before I loose the 2 hairs I have left on my head. I have a 99 e350 superduty. Starting about a year ago I've put 2 injectors, dropped the tank (cleaned the socks) only after a week had to drop it again and remove them completely (I know the tank is descaling) thats on my list, and ended up installing 1 more injector. The darn thing still runs with a miss followed by white smoke (raw fuel) and seems to take a little than normal time shifting fron 1st to 2nd and thats when the smoke takes place. I have to really hit it to move and clear the smoke but that is not working to well anymore (the filter is clean). Now on top of everything the od light is flashing
The shops out by me know less then I do (thats bad) but a least let me know which injectors are bad after paying them 200.00 for a buzz test
Anybody have any ideas??? I have more trust in you guys than the shops
Thanks In advance
Old 11-06-2009, 06:41 PM
Hello??? nutin??
Old 11-06-2009, 06:45 PM
mudrunninpig mudrunninpig is offline
D80 Axle Snapper
I have no clue, heres a bump for ya
Old 11-06-2009, 07:38 PM
late_99_PSD late_99_PSD is offline
Did you change your fuel filter when you did the tank work, or have you changed it reguarly. Also, when was the last time you changed your oil. If you got old oil in your engine, it will cause all sorts of problems.
Old 11-06-2009, 07:41 PM
jamstoyz jamstoyz is offline
if your od light is flashing and your having troubles shifting than your tranny is on its way out. my old 7.3 did the same thing.
Old 11-06-2009, 08:07 PM
Trans shifts fine after 1-2 and only does the slow shift due to low boost (thats what a friend of mine told me) he had the same prob and changed the fuel pressure reg, what do ya think?
Old 11-06-2009, 08:08 PM
the filter is new but ill change the oil tom
Old 11-13-2009, 11:10 PM
International Tech International Tech is offline
check your fuel pressure. also the line that goes into the fuel filter housing has a 45 deg elbow sometimes they get clogged with junk from the tank.
Old 11-13-2009, 11:55 PM
AgentAustin AgentAustin is offline
Send a message via AIM to AgentAustin Send a message via MSN to AgentAustin Send a message via Yahoo to AgentAustin
I thought black smoke was raw fuel.
White smoke was not enough fuel.
Old 11-14-2009, 01:50 PM
i think he is saying white smoke with the smell of raw fuel
