Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 10-27-2009, 04:55 PM
yamahardr4e yamahardr4e is offline
brake lights are on all the time
ok i have a 04 f250 and when i have my headlights on my brake lights are also on all the time. my third brake light is off until i step on the brake but the rear taillights are always on as if im stepping on the brake. what is causing this?? thanks
Old 10-27-2009, 07:56 PM
forddieseldoctor forddieseldoctor is offline
Powerstroke Techie
do the brake lights work normally when you have the headlights off?
Old 10-28-2009, 04:09 PM
no they dont when the headlights are off. but the third brake light is fine just the 2 tails
Old 10-28-2009, 04:27 PM
is there a wiring harness diagram online so i could follow all the wires to the taillights?
Old 10-28-2009, 07:39 PM
Powerstroke Techie
Not Good
Read this post. The wires colors should match up. It tells you what you're supposed to have at the multi function switch. My guess is that your multifunction switch is bad. The brake light feed comes in from the switch and then goes through the multifunction switch to the turn/brake lights. The third brake lights bypass the multifunction switch. this is why they still work.
