Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
  #11 (permalink)
Old 11-05-2009, 04:30 PM
chvyrkr81 chvyrkr81 is offline
Wait what did I click?
Ok, thanks. If he gets back on here and gives me his number, I'll put my laptop on it tomorrow.
  #12 (permalink)
Old 11-05-2009, 07:55 PM
m-chan68 m-chan68 is offline
Powerstroke Techie
Look at FICM_L, FICM_M and FICM_V under all conditions. FICM_L and FICM_V should be at, or close to 12 volts (system voltage basically). FICM_M should read between 47.5 to 49 volts. If you see FICM_M dropping to less than 45 volts, that's a given that the FICM is toast. Usually when the FICM is out, you'll get P0611 and/or all eight injector circuit low DTCs. If the FICM PIDs are all within range, you'll need to look elsewhere. FICM SYNC and SYNC should switch from "no" to "yes" when you crank the engine over. This means the PCM is getting the proper CMP and CKP inputs. If that checks out, monitor your ICP volts, ICP psi, IPR duty cycle and RPM PIDs. Your ICP volts should indicate between 0.15 to 0.35 volts at key-on/engine-off (I prefer between 0.18 to 0.24) and climb to a MINIMUM of 0.8 volts for the engine to start. ICP psi should indicate 0 at key-on/engine-off and climb to a MINIMUM of 500 psi for the engine to start. ICP desired and ICP psi should match closely as you crank the engine over. Engine cranking RPM should be between 150 to 200. The OP already stated fuel is getting to the secondary fuel filter housing so I doubt fuel supply is an issue.
  #13 (permalink)
Old 11-05-2009, 08:16 PM
fdcapt fdcapt is offline
Send a message via Yahoo to fdcapt
i think i found a new hero.. his name is m-chan... its amazing someone can just pop up this much knowledge about an engine and all the lil things that goes with it.... you my friend are my new hero....
  #14 (permalink)
Old 11-05-2009, 08:40 PM
Lol, ok I'll print this page and take it with me. IF the OP gets on here and gives me a number to get ahold of him with.
HEY OP, I need a contact number!
  #15 (permalink)
Old 11-06-2009, 05:43 AM
dbkerley dbkerley is offline
:c lap:
Guys, much praise. This is what sets us apart from the others. Absolutely amazing.
  #16 (permalink)
Old 11-06-2009, 02:09 PM
thbd77 thbd77 is offline
just got on and seen email so i came here and checked up on the situation. Let me know if I can help. Been busy and havent had a chance to get on.
  #17 (permalink)
Old 11-06-2009, 08:10 PM
Today was my chance to help, hope he gets it figured out. He ain't been back since the original post apparently.
  #18 (permalink)
Old 11-10-2009, 11:43 PM
utahnguy utahnguy is offline
You guys are amazing. I can't believe you help complete strangers like this, I wish m-chan68 was running for something so I could vote for him.
I couldn't change my own oil unless I Googled it but I could probably rattle off similar information about Windows or Mac based computers, networking, etc... I run a local onsite computer repair/consulting business and I don't ever give out free help unless it's for a family member but if any of you guys need assistance I'll help in any way I can.
I'm about to be a first time diesel owner and it's VERY reassuring to know I have a group of obviously intelligent people to come to if I ever have issues or need a second opinion to double check the local shady mechanics in my small town (nothing against auto mechanics, I'm sure there's twice as many shady computer techs out there).
