Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 10-16-2009, 08:14 PM
WDAJM1990 WDAJM1990 is offline
Truck wont accelerate!
Hey Guys/Gals, I just recently replaced my EGR Cooler, and noticed since that my truck has not been running up to par!.. The truck will not accelerate fast like it used too.. actually it took about 3 minutres to hit 50 mph.. if i floor the truck the engine just revs, and wont get out of its own way.. now if i let it slowly climb up, then punch it at 50 mph.. i can watch the rpms go up and the speed decrease.. now somebody said when i replaced the egr cooler, that i need to reset my computer to reset the injectors... BUT however, after driving the truck a while, it starts to get faster.. im puzzled about this.. anyone have this or know anyone who had this problem?
Old 10-19-2009, 09:19 PM
Socal-powerstroke Socal-powerstroke is offline
Is there any boost showing on the cluster gauge? sound like you might have forgot to plug the map sensor hose to the intake, ive seen ppl forget and the truck runs but with no boost... if the hose is connected make sure there are no rips or tares in the hose, its always good to clear codes after any repair, dont know how clearing codes would effect injector performance tho.. good luck
Old 10-19-2009, 10:19 PM
i have the 04, so i dont have aboost gauge, but i can hear it spool and hear the waste gate let air off. idk IM THINKING now after trying everything, that it might be my accelarator pedel.. any thoughts on that being the problem?
Old 10-20-2009, 09:36 PM
Is the check engine light coming on? The pedal position sensor is good with setting codes, try and read the codes see what you have, you sure this isn't a trans problem?
Old 10-21-2009, 03:42 PM
pretty sure its not a trans prob, the truck shifts great, i dont have a check engine light on though, but i was told that when you mess with the egr valve, and anytime you touch the injectors that the system needs to be reset or something of that sort. is that correct?
Old 10-21-2009, 09:56 PM
Not that i know of, i work for a ford dealer im their diesel driveability tech and ive never reprogrammed or reset anything when exchanging an egr valve or injectors, i clear all contious codes... not sure what they might be talking about... any smoke on accel?
Old 10-26-2009, 07:23 PM
Nope, no smoke on the accel, no smoke period actually. the truck runs great, idles great, starts great, shifts great, turbo spools, i just have pretty much 1/2 throttle
Old 11-12-2009, 10:02 PM
International Tech International Tech is offline
your engine doesn't have a wastegate to be letting off air...checked for boost leaks. loose clamps/hoses.
Old 11-12-2009, 10:32 PM
bama7508 bama7508 is offline
had my hpop changed the up pipe or y pipe was not perfectly lined up sounds like the problem i had
