- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
| 911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only |
error codes?
I have a superchip flashpaq programer, when I run a diagnostic scan it comes up with 9 codes
p0261 injector circ low- cylinder 1 it does this for the following 7 cylinders but with different codes and on the 9th code p0611 fuel injector ctrl mod perf |
| Sponsored Links |
Yeah the FICM is bad, the first 8 codes you got where all injector low circuit codes, these codes set because the ficm has an intergrated converter that amplifies voltage up to 48v when this inverter is bad it does not have enough voltage supply to each injector setting all 8 injector low voltage codes and a P0611 ficm performance code, it is best to take to your local dealer since this module will need to be programmed at installation or vehicle will not start..
| Sponsored Links |
