Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
  #21 (permalink)
Old 09-18-2009, 09:07 PM
m-chan68 m-chan68 is online now
Powerstroke Techie
Originally Posted by SCUFFY828 View Post
not because of charging system issues no, when i see the most ficms drop, for one , ive seen the most drop after the inductive heat flash , and two, from heat of summer
I would beg to differ on that. I have had A LOT that have come in WITHOUT the "inductive heat" strategy that has failed.
  #22 (permalink)
Old 09-18-2009, 09:10 PM
Powerstroke Techie
injectors should not be hurt , i have seen this at least 100 times, never had to replace an injector because of it
I too have had my share of "diesels" with gas in them, and have found the 6.0Ls to be far less forgiving than the 7.3Ls for this. The couple of 6.0Ls that I've had, HAVE dropped at least an injector or two. It depends on the percentage of dillution I guess. On a 6.4L, this would be an $18,000 accident.
  #23 (permalink)
Old 09-18-2009, 09:17 PM
bockhold bockhold is online now
broke college kid
Send a message via AIM to bockhold Send a message via MSN to bockhold Send a message via Yahoo to bockhold
is that what the injectors cost or the entire engine?
  #24 (permalink)
Old 09-18-2009, 09:21 PM
Powerstroke Techie
Originally Posted by RYAN SHAE View Post
SO WE DROVE OVER THE THE FUEL STATION AND FILLED IT UP WITH ALMOST 30 GALS OF DIESEL.
Who filled it up? Who paid for the fuel?
I CALLED NISSAN AND THEY CAME AND PICKED IT UP. THEY CALLED ME 2 HOURS LATER AND SAID THERE WAS GAS IN THE DIESEL AND BLAMED ME.
And just HOW did they arrive at that conclusion?
SO, NOW THEY ARE SAYING THEY NEED TO TAKE IT TO THE FORD DEALERSHIP SO THE WARRANTY WILL PAY FOR IT.
Warranty covers DEFECTIVE components, NOT owner/operator negligence. But it seems like you already knew that, so I'm just restating this for those who are not in the know. Your lucky that the dealer didn't file a CuDL contact that would've cancelled all warranty coverage.
DOES THAT EVEN SOUND RIGHT? FORD WON'T WARRENTY THEIR DUMB MISTAKE WILL THEY?
NO and NO.
ALSO DO YOU THINK THAT IT MIGHT HAVE HURT THE INJECTORS OR THE ENGINE IN ANYWAY?
Quite possibly, yes. You may luck out now if you keep filling it up with a good quality diesel fuel and RELIGIOUSLY use Ford's PM-22-B (PM-22-A for you Americans) and PM-23-B (PM-23-A for you Americans) additives on EVERY fill up.
  #25 (permalink)
Old 09-18-2009, 09:25 PM
Powerstroke Techie
EVERYTHING that fuel passes through, including the high pressure fuel pump that requires cab removal to access and replace.
  #26 (permalink)
Old 09-19-2009, 06:02 AM
RYAN SHAE RYAN SHAE is offline
What is that additive that you are talking about? I really don't know how they came up with the gas in the diesel thing. I think it was all just a lie. They didn't want to fix it and they wanted me to pay for the towing and everything else. Also, the Nissan salesman field it up. I was standing right there and I know he put diesel in it. They even pulled his reciept and it showed diesel not gas. He used to be one of my welders and has been around diesels all his life. So we know that when it happened (if it ever really did happen), then it was before I even looked at the pickup on Monday morning. Also I think that all the single fuel tank will hold is 32 gals right? Maybe 36 gals? If so then it only could have had 4 gals or less of gas in it anyway. Because we put 2 gals in it to get it to the fuel station and then filled filled it up. I think we put 30 gals in it when we filled it up. I just think that was a bunch of B.S. from the dealership.
  #27 (permalink)
Old 09-19-2009, 07:14 AM
ryandamo ryandamo is offline
that sucks, gotta be careful with these dealerships their out to get you
