- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
| 911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only |
door ajar/ open !! cab lights are on !!!!!
the darn door ajar/open light is on and i cant get the dome lights or the box light to turn off ......i have shut every door several times.....took a rag and wiped off the rubber around door and still cant get the beepbeepbeepbeep lights to go out......
where is the fuse located at to kill the dome lights ????? i need to go to work in the morning.... and was hoping to get help from you guys before i disconnect the batteries....... please help.... thanks in advance for you help... |
| Sponsored Links |
If you have anymore trouble try this stuff, KanoLabs.com
I have the darn door ajar light and dome light staying on A LOT now. The light will go off after the tach. is above about 1,500. I tried spraying the door latch with brake cleaner but it did not help. What would you all recommend to fix this? Where exactly should I be spraying, I don't know what the sensor or switch looks like. |
Thats
what worked for me was a bunch of brake cleaner,the i sprayed with silicone spray it has not done it since.also anybody in cold climates if you spray silicone on the weather striping your doors wont freeze shut! also works for key locks
| Sponsored Links |
