Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations
911 Urgent Situations Emergency Forum , Need Help Fast ? Post Here ! Urgent Topics Only
Old 06-28-2009, 10:52 AM
heard farms heard farms is offline
2004 F-350 crank no start...Replaced crank sensor still nothing
I have a 2004 F-350 with the 6.0 diesel I drove about 150 miles and started and stoped several times then parked it for the night. I went out the next morning and it just cranked and cranked. Fuel gauge was at 1/4 tank I opened the fuel filter and it was full. I scanned for code's and did not find any so I replaced the crank sensor and that did nothing. I get oil pressure reading while cranking so I don't think it is the HPOP. Any idea's or tips on what to look at would be a great help.
Old 06-28-2009, 10:59 AM
billelf123 billelf123 is offline
I am not a 6.0 guy but the FICM's are common problem with 6.0's. Maybe the CPS? May not be the problem but here is a bump anyway...Good luck!
Old 06-28-2009, 11:08 AM
I have been searching the net for the last 12 hours and I have came up with a few answer's of the FICM possibly causing this issue. I did get a couple of DTC code's off the dash.
DTC A477
DTC 9352
Old 06-28-2009, 11:13 AM
ianstew ianstew is offline
Go ahead, swat the screen
FICM's are not cheap, hope it's not that. maybe scott or another tech will chime in for ya.
Old 06-28-2009, 11:29 AM
mudrunninpig mudrunninpig is offline
D80 Axle Snapper
I had a similar issue and it was my FICM. heres a bump for ya maybee Scuff will see this
Old 06-28-2009, 11:37 AM
Found some info on the net for EGR and Injector failure...really nothing you can put a finger on!
Old 06-28-2009, 11:59 AM
Old 07-08-2009, 07:00 PM
Just wanted to update you fella's it was the FICM.
Old 07-09-2009, 09:14 PM
Glad your truck is fixed!
