88 7.3 diesel info - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #1 of 16 Old 02-04-2009, 06:54 PM Thread Starter
jitt08's Avatar
Thumbs up 88 7.3 diesel info
hello my name is mike im thinking of buying a 88 nonturbo diesel truck and was wondering if you guys would help me with some good and bad info about the truck thanks mike
99 3500 auto drw 5" adrenaline and lovin itsilencer ring m.i.a.
I support
CENTER][/CENTER]100%
jitt08 is offline
post #2 of 16 Old 02-04-2009, 06:56 PM
Cory S's Avatar
hey man my dad used to have an idi and that thing was a beast! and parts were way cheap!
Vegistrokin
2000 XC 4x4
-CORY
Orlando, FL
Cory S is offline
post #3 of 16 Old 02-05-2009, 01:10 PM Thread Starter
jitt08's Avatar
bump bump bump
I support
jitt08 is offline
post #4 of 16 Old 02-05-2009, 07:29 PM Thread Starter
jitt08's Avatar
anymore info come on guys
I support
jitt08 is offline
post #5 of 16 Old 02-05-2009, 07:41 PM
baddkarmaracing's Avatar
Quoted: 3 Post(s)
the good : reliable, relativly cheap
the bad: they are slow lol but that can be fixxed with a little work just turn up the pump and adjust the timing
2008 F250 6.4 CC SB Fx4
Gearhead tunes, flopro exhaust,AFe intake
baddkarmaracing is offline
post #6 of 16 Old 02-05-2009, 08:07 PM
FordGuy100's Avatar
An 88 will have a 7.3 IDI, so I will lists its faults
They took the 6.9 IDI (circa 1983-1986) and bored it out to 7.3 liters. This made the cylinder walls thin. Without a special coolant additive (SCA), they can cavitate over time (small holes in the cylinder walls). Coolant in oil, oil in coolant, that type of thing. You can buy a SCA test strip kit from your local store, test the coolant. If its up to spec, then good, if not, I would walk away.
They changed the valve guide design from the 6.9 IDI (the 6.9 design caused them to burn oil). But in doing so, it sometimes causes valve failure, which results in a F'ed up engine.
Those are the two major things wrong with them. You can go more into depth, little things like the glow plug controller stops working if 1 glow plug goes bad, but all in all they are good engines. Parts are easy to get, and cheap. They really truly only need a couple wires to make them run, and are way easy to diagnose and fix. A true, mechanical engine, easy for the average backyard mechanic to fix.
-Justin-
1985 Ford F-250 with a 6.9 IDI/T-19 4speed 4x4
Paint, Eagle Alloys, Kelly Safari TSR's, ATS turbo, gauges
2004 Jetta TDI 5 speed
2004 2wd Excursion Limited 6.0. Testing how loyal I am to Ford
1997 Passat B4V TDI. 1 of 80 imported in 97. 50 MPG and a factory 25 gallon fuel tank!
FordGuy100 is offline
post #7 of 16 Old 02-06-2009, 06:20 AM Thread Starter
jitt08's Avatar
hey thanks guys
I support
jitt08 is offline
post #8 of 16 Old 02-18-2009, 03:44 PM
cc.mud slinger's Avatar
transmission?
[QUOTE=FordGuy100;1008203]An 88 will have a 7.3 IDI, so I will lists its faults
Im looking at an 1986 7.3L IDI 4x4 and am wondering about the manual transmission. Is it a 4 or a 5 speed ? I just want to know.
Any information would be helpful. Thanks.
cc.mud slinger is offline
post #9 of 16 Old 02-18-2009, 03:47 PM
FordGuy100's Avatar
If its factory, then it should have a T-19 4 speed tranny. They are strong, but no overdrive. It could have a ZF-5 speed swapped in though, not as good of a tranny, but it has overdrive.
-Justin-
post #10 of 16 Old 02-18-2009, 03:52 PM
which is better for offroading? If I get it, it will spend most of the time offroad. Thats why I ask. Thanks
