5 speed swap - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
Old 12-30-2008, 06:50 AM
Send a message via AIM to blowinsmoke4life
5 speed swap
I might be being a 5 speed soon and i was wondering wat all will I need to purchase for this swap. I know i'll need a manual flywheel, clutch, and obviously the tranny itself. what else will i need? Thanks in advance
Old 12-30-2008, 06:57 AM
Old 12-30-2008, 04:43 PM
Old 12-30-2008, 04:56 PM
Also a truck to put the trans in!
Pedal assembly, manual steering colum, slave cylinder, transfer case for a manual tranny (maybe), manual instrument cluster, 4X4 manual tranny,
Old 12-30-2008, 04:58 PM
5 speed
Pretty sure you'll need a bell housing
Clutch pedal and clutch master/slave cylinder assembly
Inspection cover
Go with a solid flywheel (dual mass are junk)
All I can think of right now....
Old 01-01-2009, 07:58 AM
No bell housing. They are part of the trans.
Old 01-13-2009, 03:11 PM
what about driveshaft? are the auto and 5speeds the same lenght?
Old 01-13-2009, 05:49 PM
I think you might need the driveshafts but I am not sure.
These guys basically got it all. You dont need all of it, like a manual steering column, though it would be nice.
Tranny
Transfer case, though you can use yours if its a BW 1356 or 1345
Peddle assembly
Clutch slave cylinder
Clutch line
Clutch master cylinder
Flywheel (single mass are the best, stock are dual mass and wear out over time)
Clutch
Driveshafts
Steering column (if you have to have it)
Gauges (if you have to have it)
Shifter (s)
Shifter boots
Floor pan were the shifter go through on the manual tranny, they are different shapes for the different trannies
Thats about it. Have fun with it . I would personally try to find a overdrive unit, about the same money in the long run, and you wont have to deal with a weak tranny (at least compared to my T-19). Plus you dont have to listen to that dang gear rollover noise ZF's make (like nails on a chalk board to me)
