92 f-350 dually - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #1 of 6 Old 01-09-2006, 09:30 AM Thread Starter
Post 92 f-350 dually
having problems starting cold, will start then stall when cold even when plugged in and inside the shop starts right then stalls will only restart with ether new starter spins plenty fast enough anybody help please
abhd81 is offline
post #2 of 6 Old 01-16-2006, 04:44 AM
stomper2's Avatar
There's a Cummin's next door to me with the same problem, only it will die 3-4times when its below 35 deg. Could you glow plugs/relay be bad?
stomper2 is offline
post #3 of 6 Old 01-16-2006, 11:09 PM
overl0rd's Avatar
Have you tried jumping it?
'96 F250 4x4 Ext Cab, 5 speed. K&N FIPK - modified to use 6637; 3" downpipe, 6" stack; Beans modded IDM; Beans stage 2s; shimmed FPR; exhaust brake; 6 position TS; locked 4.10s
'93 F250 4x4 regular cab long box. 7.3IDI nonturbo/E4OD 8' Western. STAYING STOCK
'65 Pontiac Tempest, 406ci chevy small block, TH350 with shift kit, 2700 stall converter.
'01 HD XL1200S - Lots of Screamin Eagle goodies
'96 Tbird LX V8
Progressive loves me
overl0rd is offline
post #4 of 6 Old 02-14-2006, 05:12 PM
wesjones's Avatar
check out the fuel delivery system...if you have a new starter, and you are plugging it in, it sounds like an engine problem, not a start problem....check that out before you put more ether in the truck...my dad has to hide the starting fluid from his drivers so they don't use it...its not too good for the engine....good luck with your problem....isn't your 92 a non turbo?
wes
wesjones is offline
post #5 of 6 Old 02-14-2006, 05:48 PM
try hitting the fuel pedal and releasing it before starting it. there is essentally a "choke" built into that throttle linkage....also look for fuel leaks.......Marc
mschn99 is offline
post #6 of 6 Old 03-24-2006, 07:07 PM
fuel problem
I had this same problem on a 93 non turbo I relaced the timing sensor on the #1 injector the ceramic element gets cracked causing it to draw air and loose it's prime
dsl-mechanic is offline
