| 7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines. |
Southbend clutch not disengaging
So I just installed a brand new southbend clutch in my 88 f350.
It wont quite disengage with the clutch with the pedal all the way down. The old clutch worked fine other than the dual mass flywheel distorying itself.. So i'm confused. Anybody else have this problem? The only thing i can think of is the bushing between the clutch pedal and the master cylinder pushrod is worn out but thats only like a 16th of an inch.. Thanks in advance! Last edited by zigphroid; 11-17-2008 at 09:14 PM. Reason: updated for clarity |
you should try to bleed the system man if you got a little air in the system then you will have to get it out but good luck man. did you change the fork out?
Master cylinder leaking down?
+1 Bleed it. Maybe some material worn from the seals in the master got pushed back when the clutch went in and is holding the edge of a seal open in the master. Flex at the firewall? I've heard this can be a problem. Have someone look while you push. |
