Transmission Overheats - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
Old 11-10-2008, 07:32 AM
1994 F-350 7.3 Non-Powerstroke. When towing a heavy load the transmission overheats and dumps fluid. What's up with that?
Old 11-10-2008, 08:29 AM
Send a message via AIM to International-Harvester91 Send a message via Yahoo to International-Harvester91
What exactly do you mean dumps fluid, where? and how much?
Old 11-10-2008, 08:34 AM
The "bottom front" has a tube sticking down about the size of a straw, it dumps it there and dumps several quarts.
Old 11-10-2008, 08:35 AM
what temps are you seeing on your trans?
Old 11-10-2008, 08:40 AM
Don't know, this truck is completely stock
Old 11-10-2008, 08:41 AM
i would suggest putting some gauges in it.. that way you can monitor what its doing... knowing the temps your hitting while your towing is crucial
Old 11-10-2008, 08:50 AM
im sure you know but make sure the fluid level is good and check it warm, and i think that might be a tranny cooler line? Im not sure though
Old 11-10-2008, 08:53 AM
COLLEGE KID
Send a message via AIM to lifewitlooie
if you get guages you can see what temp your tranny is running at and that will get you started. "Tanks library" has a tranny temp chart where you can estimate miles until failure based on operating temp.
Maybe this will scare you into gauges. Even at this hot my tranny has not dumped fluid.
