Leaking injectors - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
Old 11-04-2008, 07:50 AM
Send a message via AIM to International-Harvester91 Send a message via Yahoo to International-Harvester91
Question Leaking injectors
Hi everyone i, first off have to say that i am fairly mechanically inclined but i do not know much about diesels. The other day i looked at my injectors and they are leaking diesel onto the intake manifold. This seemed to happen after i turned up my pump, but i did not turn it up much and i have a pyrometer and all is good there, so i just think the seals are worn out. The only place i can really find the parts i need is here. 1991 FORD F-250 SUPER CAB Fuel Injector O-Ring
Now i dont know if that is a good price or not so any input would be awesome, and would it be a good idea to replace the injectors while i am at it? Thanks and once again im not good with diesel matenece so any help or input would be awesome
Old 11-04-2008, 08:21 AM
ADMIN AND TECH
the o-rings are usually the problem, no need to replace injectors, oh and be carefull with the caps , they will break
Old 11-04-2008, 09:07 AM
im pretty sure i probably already broke one trying to tighten the lines haha but i think that kit on rock auto (the link above) has the caps with it well it better for 75 bucks, it has a pic in it if you click more info
Thanks, Jordan
Old 11-04-2008, 09:24 AM
Cynic
I agree with the o-rings. Be sure to remove each line separately.
I'M KIDDING! Remove it as one piece. I got a call the other day asking how each line came out!
Old 11-04-2008, 09:39 AM
now you got me confused man lol, but it looks like the lines can only come out one way
Old 11-04-2008, 09:41 AM
Cynic
They do as far as I'm concerned. But apparently that doesn't stop people from trying craziness.
Old 11-04-2008, 10:02 AM
ok thanks alot and i have another question, with my stock set up in my truck just turned up the pump a lil, the max i have gotten the pyro up to was 850 deg, thats tromped going up a hill, is that ok or should i be concerned?
Old 11-04-2008, 10:05 AM
Cynic
Sounds like you advanced the pump 2 maybe 3 teeth. Sounds fine.
Old 11-04-2008, 10:08 AM
ok thanks for all of your help :]
Old 11-06-2008, 10:30 AM
ok guys sorry to bring this back up, but i just got a kit that has o rings brass washers i believe and a hose and hose clamps and the injector caps, my question is how do i purge the injectors, or remove the air in the lines when im finished?
