92 non turbo - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #1 of 9 Old 11-19-2006, 05:26 PM Thread Starter
92 non turbo
Hey guys,
My dad has a 92 F-350 CC, non turbo 7.3, 5 spd. Is there any way to get more power out of it? It's pretty much a gutless wonder. The local diesel shop says a turbo isn't a good idea, something about the internals isn't up to snuff. Thanks!
95 F-350, RCLB, ZF-5, 35" BFG's
chadow427 is offline
post #2 of 9 Old 11-19-2006, 06:35 PM
Powerstroke Techie
djsdiesel's Avatar
You can turn the pump up. And yes you can add a turbo, Ford did it from the factory in late 93 and early 94. There are a couple of aftermarket ones available. If you do a search on turning pumps up on 6.9l/7.3l IDI engines you should turn up some info.
99.5 F-250 PSD AT 4x4, 4in lift, 37 13.5 18 Pro comp Extreme A/T's, S&B Intake, GTP38R, DP Tuner custom programs (140 Agg., 120 sled pull, 80 tow and 60 tow), Rosewood DIY stage 2 injectors, BTS Trans, 5in exhaust no muffler, 6 oh intercooler, Ford AIC, EBPV delete, Foil delete, T/C lock up mod, Pusher Fuel Pump, Three Chime train Horns
djsdiesel is offline
post #3 of 9 Old 11-19-2006, 07:40 PM Thread Starter
I've tried some searches, haven't had much luck....wanna help a guy out?
post #4 of 9 Old 11-23-2006, 06:06 AM
squeeks's Avatar
if found this, might help.
http://www.members.shaw.ca/k2pilot/I...%20article.htm
1996 Ford F350 Regular Cab 5spd with the 7.3L PSD, 4x4, 35.5x12.5x16.5 All-Terrain T/A's, 3.73s', DIY Electric Reg Return Fuel Sys, 3" Downpipe, AFE Stg 2, 17* HPOP, IDM Mod, SB Con-O, Cat and Muffler Delete, AutoMeter NV Series Boost, Fuel Press. and Pyro, Autometer 3 Pod A-Pillar, TS Performance 6 Pos Chip. HPX Mod, 335,000 Miles
squeeks is offline
post #5 of 9 Old 11-23-2006, 06:13 AM
Brian's Avatar
contact some sponsors here, im sure they can hook your dad up.
brian
05 f350 crew, longbed, 4x4, 68k, lariat
Brian is offline
post #6 of 9 Old 11-24-2006, 05:10 AM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
Banks and Hypermax make tubo kits for them.
I've heard the Sidewinder kit from Banks really wakes the engin up, but don't look for PS power without more mods.
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #7 of 9 Old 11-24-2006, 04:27 PM
overl0rd's Avatar
Lem posted a write up on turning the pump up, it should be in the articles section.
'96 F250 4x4 Ext Cab, 5 speed. K&N FIPK - modified to use 6637; 3" downpipe, 6" stack; Beans modded IDM; Beans stage 2s; shimmed FPR; exhaust brake; 6 position TS; locked 4.10s
'93 F250 4x4 regular cab long box. 7.3IDI nonturbo/E4OD 8' Western. STAYING STOCK
'65 Pontiac Tempest, 406ci chevy small block, TH350 with shift kit, 2700 stall converter.
'01 HD XL1200S - Lots of Screamin Eagle goodies
'96 Tbird LX V8
Progressive loves me
overl0rd is offline
post #8 of 9 Old 12-27-2006, 06:42 PM
Turbo Upgrade
I also have a '92 F250 and at the time I bought it 2 years ago the performance at highways speeds was similar to yours: a gutless wonder. About a year ago I installed a used ATS turbo onto the motor. I was towing a car (on a trailer) from Eugene, OR to Chico, CA when I stopped midway to pick up the turbo unit in Ashalnd, OR and then drove over to Klamath Falls, OR to have the turbo installed by a good diesel mechanic there. On the way to K-Falls the truck slugged it out along I-5 doing, if I was lucky, 55-60 MPH. After installing the turbo I left K-Falls and headed south, facing a long grade to get out of town. Pre-turbo I would've been lucky to maintain 35-40 MPH towing that car. The turbo effect is nothing short of magic: I found myself having to throttle back 1/4 way up the hill just to maintain the speed limit (55 MPH)!
So I can unequivocally say that putting a turbo on your '92 is not only feasible, it's a virtual necessity if you're going to tow anything. Highway mileage has remained about the same unloaded (14-15 MPG) but towing mileage went up significantly (from 8-9 MPG to 11-12 MPG) and going over passes at higher altitude you can really tell the difference in performance.
My (barely) used ATS turbo cost $500 + $300 to install...and worth every penny :-).
cuzneddie is offline
post #9 of 9 Old 11-10-2007, 03:47 PM
Cool
Originally Posted by chadow427 View Post
Hey guys,
Ive noticed this attitude from a few mechanics and it seems to me they are going by the general rule of thumb for gasoline motors. You have to change all kinds of things like pistons and what not for gas. These diesel IDIs will take a straight bolt on from places like Hypermax which incidently has max goodies for our 7.3 Navistar IDI diesels. It dosent mean there is no work involved but its nothing like a gasoline turbocharging which might as well be a ground up rebuild. Hypermax -Power Stroke Diesel Performance Ford Diesel Power, 5"exhaust, power module, power chip, injectors, intercoolers, turbochargers
cpharrboy is offline
