Blew da head gaskets! - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
Old 12-28-2005, 10:32 AM
I just blew the head gaskets on my 7.3 turbo IDI. Does anyone have access to the manual for a 94 7.3 TD IDI w/4wd? I need torque specifications and anything else I can get my grubby paws on. Thanks.
Old 12-28-2005, 11:05 AM
Send a message via MSN to turbotime Send a message via Skype™ to turbotime
What a crumy thing to happen. Sorry that I dont have the info that you need available to post for ya. But good luck with the fix.
Old 12-28-2005, 11:30 AM
Power Strokeaholic
ok tyrfryer, at last somthing i can help w/.my manual says and i quote "1992-1993-1994 non DI turbo.first step 65, second step 90, third step 110 Ft-lbs"
from the Haynes book.it doesent show the seq. but if you need the V.C. exh. manifold or other specs let me know.
Old 12-28-2005, 01:06 PM
Thanks a lot. I'm gonna need intake, exhaust manifold, valve cover, turbo housing to exhaust flange, & turbo housing to downpipe for sure as well. Not sure if I'll need any others.
Old 12-28-2005, 01:25 PM
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
Hey Tyr here's what I looked up in my haynes manual:
Intake: 24ft-lbs
Exhaust manifold: 20ft-lbs
Valve cover: 72in-lbs
I can't find anything in my book on the turbo torque specs that you need. I'm sure someone on here will have the answer, but until then i'll try to get ahold of my ford mechanic buddy and see what he says.
Old 12-28-2005, 02:05 PM
Thanks much. I found some info @ dieselman's web site also. Wish my autozone carried a haynes for it.
Old 12-28-2005, 02:06 PM
Power Strokeaholic
what he said about the other stuff. all i have is turbo mounting bolts 18 ft-lbs and turbo exhaust inlet adapter bolts 36 ft-lbs. it doesnt specify engine on that though. so that may not be it. as for the down pipe "thats about right" tight sounds good. dont it?
Old 12-28-2005, 02:34 PM
I got my Super Duty Haynes from Auto Zone, but I had to order my Haynes diesel engine manual.
Old 12-28-2005, 05:36 PM
Just found that A-zone has the manual on-line, thanks for the help everybody!
Old 12-28-2005, 08:31 PM
Send a message via ICQ to overl0rd Send a message via AIM to overl0rd
