Cummins conversion - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #1 of 13 Old 08-30-2008, 04:24 PM Thread Starter
blowinsmoke4life's Avatar
Quoted: 2 Post(s)
Garage
Send a message via AIM to blowinsmoke4life
Cummins conversion
I just recently got back to school and at my vo tech school i go to for a half a school day we have a 94 dodge 3500 2wd drw that we might be tunrning into a pulling truck but instead of keepin the cummin 12v in it we were going to take one ofthe CAT 3116's we have and hook that up to aonther trans we have to fit it. And seeing that the cummins will be no use to him I asked him if i could ahv it to put in my 89 and he was liek lemme think bout it. And i was wondering would it be worth it. I've already found a site the ahs a 12v engine mounting kit for my 89 and i looked up everything and i was gonna get rid of the C6 tran i got now for a ZF-5 manual trans and it came out to around 2800 to 3000 dollars seeing that i might be gettin this engine for free. so i was jus wonderin what your guys thoughts werre and if thsi is alot harder then im thinkin.
1999 F250 CC SB 4x4 4r100 ts chip w/ php tunes
1989 F350 CC LB 4X4 N/A 7.3l IDI zf5 swapped and rebuilt engine. sold
blowinsmoke4life is offline
post #2 of 13 Old 08-30-2008, 04:27 PM
a truck
Matt P's Avatar
I think it would be worth it the 12v is a great engine that you can get a lot of power from and since its all mechanical its easier to swap since you dont have a mess of wiring to worry about converting. So i would say go for it
03 king ranch w/ a cummins
Matt P is offline
post #3 of 13 Old 08-30-2008, 04:47 PM Thread Starter
Quoted: 2 Post(s)
Garage
post #4 of 13 Old 08-30-2008, 05:16 PM
Tikal's Avatar
Send a message via AIM to Tikal
If it was free I'd be all over it
~Bo
94.5 F-350 Dually
7.3L 5spd
Grand Rock 6" Aussie's
D.I.Y. Stage 1 Injectors
Tony Wildman 6pos Chip
Optix Guages (boost & EGT)
DIY Tymar, CCV mod, FPR Shim
Tommy-Lift: so I can date fat chicks
I don't smoke cigars, I smoke pipes!
Tikal is offline
post #5 of 13 Old 08-30-2008, 05:40 PM
jamstoyz's Avatar
i would do it but the only bad thing with a 94 cummins is you start off with a base hp rating of 190 hp and 40ft pds of torque. i think the 981/2 twelve valve was the best motor to swap cause it had a higher hp rating stock. but with injectors, fuel setup, and a set of twins that thing should rock. i know a guy with a very clean obs with a cummins in it and it sounds so sweet. sounds like the thing has a huge cam the way it lopes.
05 Single Cab Short Bed
*03 Turbo*Stroked Injectors*AFE Stage 2*Small mouth Intake*SCT With Eric's Extreme Race*4.30 Gear*Best ET 13.5@99MPH*
jamstoyz is offline
post #6 of 13 Old 08-30-2008, 06:46 PM Thread Starter
Quoted: 2 Post(s)
Garage
post #7 of 13 Old 08-31-2008, 10:16 AM Thread Starter
Quoted: 2 Post(s)
Garage
post #8 of 13 Old 08-31-2008, 10:41 AM
a truck
Matt P's Avatar
yeah the first half of 98 was the last of the 12valve in 98.5 they switched over to the 24valve so the early 98 before the 12valve was discontinued would have the most power
Matt P is offline
post #9 of 13 Old 10-24-2008, 09:45 PM
psd tuner's Avatar
12v for free...i would go for it. there is so much power you can make out of that motor. grind the fuel plate flat, move the afc housing foward and the fuel plate foward, turn the star wheel, add a 3k gsk, and bump up the timing. thats just some mods for the pump. then you can do turbo injectors and such. but yeah it wouldnt be too terribly hard i dont think just have to make some dodge stuff fit in a ford or buy some adaptors for stuff like the ps pump, a/c com., and other stuff.
2010 Ford Focus blacked out and fswerks exhaust.
2008 F-350 xl cc/lb 4x4 dpf delete, PDF-r tune and s&b cold air kit.
psd tuner is offline
post #10 of 13 Old 10-25-2008, 05:34 PM
Runnin'wita2cylhandycap
OneBigDoofus's Avatar
If no ones messed with it that motor should be a 160 hp me thinks. That pump will have small delivery valves and you will not get a very big kick in the azz frum grinding the plate or the other pump mod. 96ish models and up have the bad mother pumps with big DL valves. How many miles are on it?
Hey man,...if it's free,....goferit!
The only "Tuner" in my truck, must have fell out of the wifes Tunerfish Sandwitch.
OneBigDoofus is offline
