Go Back   Ford Powerstroke Diesel Forum > Pre-Powerstroke Diesel Section > 7.3L IDI (Non-Powerstroke) Diesels
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
Old 06-05-2008, 08:05 PM
james.mcmurtry james.mcmurtry is offline
93 turbo-diesel, history of starter fluid
Have a 93 turbo 7.3 with history of having starter fluid as a starter helper. can someone make me smart on the problem and fix?
Old 06-06-2008, 06:45 PM
A little more info--am trying to get truck most recently used by my son up and running reliably for my farm, and have found a shot of starter spray has been needed during my efforts.
Have read on previous posts about starting issues about not using spray. Would like a refressher on why and, if it has happened, how to correct.
Thanks.
Old 06-07-2008, 08:28 AM
Gruss Gruss is offline
An IDI will start reliably with the glow plug system operating correctly, a good starter, batteries, injection pump, and injectors. Either is very hard on diesels that have a glow plug system. IF you want to use either(not recommended) disable the glow plug system.
Old 06-09-2008, 10:28 AM
Gonna try fuel pump
Was thinking about it over the weekend, now suspect a bad check valve on external fuel pump. Starting spray (small amount) gets engine started, then is good for rest of day.
Need for ether only occurs a day or two later--believe fuel drains back to tank from pump during that downtime.
Jim
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
