| 7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines. |
turbo for idi
hey i was thinking of buying a turb from either banks, ats, or hypermax. but then i got to think i could make my own turbo system but bcuz my truck has 20:1 comp. ratio i dont kno how much boost i can run. so if anyone could help me tell me how much boost i can run so i can get workin on my turbo system thanx.
if your willing to spend the money banks
but the hypermaxx pulse turbo is bad as hell for pretty cheap ats isnt bad if your planning on rebuilding i would send it to majestic turbo in waco texas they can do some pretty sweet **** |
My 92 F-250 7.3 has a Banks sidewinder turbo setup on it when I got it....
The Banks Boost guage says I'm only hitting 11 pounds of boost. So I'd say there's your safe starting point to get your turbo set up for your truck. |
thanx for the help
IDI's run around 21.5:1 Compression ratio. Unless you shaved your pistons, your should be the same (dont know if you have done that or not). Anyways, with 21:1 CR, I would say around 18-maybe 20psi max. Some people push stock CR IDI's to 15psi, I dont, cause I have stock headgaskets and head bolts (bad headgasket design on 6.9's from the factory, and head bolts plain suck, head studs are better). If you want to run a custom turbo, use a stock OBS PSD turbo, or second gen 7.3 psd turbo. It will be custom though, and we require a lot of fabrication and skill.
ook thanx
