Now What? '94 Stock F250, what should I do for her? - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #1 of 4 Old 08-19-2013, 07:25 AM Thread Starter
Hello and Good Morning Forum,
I Bought this 1994 F250 Pre PSD, IDI 7.3L, all Stock truck with 156,000 miles on her, last October. She had some problems, not major, but some - and due to low $$$ in pocket - she sat for awhile until I was able to get her to a driving condition.
I replaced brakes all around, wheel bearings, 2 new batteries and finally glow plugs. Once this was all done, she was now close to becoming a driver.
The weekend before last, I changed Motor oil & filter. Came out Black!!
Next day, changed ATF. Dropped pan and also emptied TC. New filter and NAPA Premium DEX/MercIII, with NAPA Trans Kit. Side note: Fluid not too bad, didn't smell bad, but it was not fresh either.
Found a valve body bolt stuck to the magnet. Found the hole & put it back. No big deal, I hope?
Last Wednesday the O/D Off lite started blinking and I think I have a slipping T/C.
Pulled the code 62 in memory. Not a Hard current code.
So, I Need to baby her for awhile to once again pad my pockets with $$$.
I think I am going to tackle a rebuild myself. Will consult with forum later as I begin to near this project.
Now, to topic of this Thread: What minimal mod's can or should, I do to this truck to bring her up from stock that will greatly help her? I think I probably should get some Gauges? Which ones. Same as most (I put on my '96 EGT, Trans Temp & Boost).
What have some of you done to & for your IDI?
Would truly appreciate your opinions, experiences and valued assistance?
Thanks to all
Truck #1 - 1996 F250 PSD 4x4 w/4" Lift - AFE Air Intake, Rebuilt Modded Turbo, TS 6 Position Performance Chip, Rebuilt Stage I Injectors, AutoMeter Phantom II 3 Pod Pillar, Rebuilt/Modded E40D, Procomp ProRunners, After Market RKE w/Remote Start and a Smelly Tree on the rear view!.
Truck #2 - 1994 F250 XLT 7.3L Turbo (IDI) Pre-PSD, SuperCab, Banks 3" DP, 4" Pipe to a 5" Double Wall Chromed Tip. DIY Air Intake with 6637, BB Injectors, Alloy ProComp Classics, Long Bed
damedic is offline
post #2 of 4 Old 08-26-2013, 08:56 AM Thread Starter
Lift Kit??? 1994 idi F250 Turbo
Hi, I guess this may be a Bump???
It seems that no one has an idea or opinion to share or help a newbie with a completely stock rig, on what I can do for my 1994? What is the most common for or maybe absolutely a "Must" for a 7.3L truck.
If there is such a thing as Must?
Anyway, with lots of reading, and just guess work, since I have no where to turn but the forum (where no answers - huh )
I am going to start with opening the airways. I am going to replace the cold air intake. Already ordered it, just need to find time to install it now.
I would like to attempt to get better fuel economy to start with. I am not a "Hot Rodder", so major performance to put HP and Torque to the ground is not really what I am after, but if I do need to pass the occasional vehicle in my way, that ability wouldn't hurt!
Anyway, I now want to change out my stock steel wheels that have a "Fancy" cover to ones that are slightly bigger. I have an opportunity to get a great deal from someone who is getting rid of their rig that has some nice wheels & tires.
I think that I will not have the clearance for them so, I have been looking to find a moderate "Lift Kit" to accommodate the larger wheel. I can't find anything that will work on any of the sites. Each time I put in more & more details about the rig, the large list of kits, quickly disappears from which to choose. And a couple sites, like Summit Racing, gave me (at the end of the detail process) 2 choices for "Body" lift. Then when reading the install details - I find:
"Will not fit trucks with Diesel engines". Sheeeesh
So, I am asking again hoping to find an answer: What is available for this truck to lift it moderately at 2-3 inches. I know after looking at lots of pics of some real beauty's on the ORG - that this is possible? What have you guys used? I presume that since there is no "Cookie cutter kit w/easy install and go type kit - some modification may be needed? And is there a difference of "Importance or Preference" of a lift kit - body vs. suspension?
I am new to all of this and am trying to learn as I go. The other truck in my sig, was that way when I bought it, except for gauges, which I installed.
So, thanks again and will appreciate all feedback!
damedic is offline
post #3 of 4 Old 11-02-2013, 06:40 AM
Send a message via Skype™ to 2004strokerJeremy
The pre psd is a raw powerhouse. My dad has a 94 f350 and it's a beast. Since it's a mechanical injected and has no turbo the only thing a chip will control is the slip-o-matic. The 7.3idi is the holy grail of diesels. If the O/D light is flashing and it can decide what gear to stay in, rip it out and go with the 5 speed or a 6 speed(if you can find one) 5 just isn't enough gears with our f350. You can get cold air intakes fairly cheap and replacing the injectors and injector pump probably wouldn't be a bad idea. We got ours pretty cheap from Pensacola diesel, great customer service too.
Sent from AutoGuide.com App
2004strokerJeremy is offline
post #4 of 4 Old 01-04-2014, 04:13 PM
Fordtough82's Avatar
Personally I prefer a suspension lift both of my trucks had a 4" lift in them...as far as mods for the idi all i have done is turn up my pump a little and put an aftermarket downpipe on it my od light flashes when i let off the accelerator and the rpm drops same time the tach stops working pretty sure its the rpm sensor causing it all...dont get me wrong I would prefer a 5 speed but I got my truck with a reman trans in it already so no point in wasting money till I have to....
06 F-250 long bed ext cab 4x4
Diesel Repair and Custom Performance
Fordtough82 is offline
