Go Back   Ford Powerstroke Diesel Forum > Pre-Powerstroke Diesel Section > 7.3L IDI (Non-Powerstroke) Diesels
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
  #21 (permalink)
Old 05-15-2008, 08:28 PM
bronco.2 bronco.2 is offline
pretty sure but when in doubt make it stout.. cool lordco ( local parts store ) as a half tool box and half 40 gallon fuel cell in there store for around 400 or so right now and it is really temping, haha mm mcdonalds used french fry oil haha...
  #22 (permalink)
Old 05-15-2008, 08:58 PM
somebodyelse5 somebodyelse5 is offline
Nice find! always great to find something lilke that, especially one that you look at and see something even better!
There are some SWEET obs trucks, i have an extended cab 150 that body style....they look goood! haha
  #23 (permalink)
Old 05-17-2008, 07:54 AM
jeepguy88 jeepguy88 is offline
I bought a new TPS sensor. How do you set them in place?
  #24 (permalink)
Old 05-18-2008, 03:06 PM
Anyone? I dont have a book that covers the TPS. How do I adjust it. Now when I let off the throttle, it dies, and the OD light is blinking.
Good news is I replaced all the glow plugs, and she does start pretty easy now. Just down to the tranny issues, and the well the TPS sensor adjustment.
Here is and updated pic, Pressure washed, hand washed and waxed with some matching tires and wheels.
<a href="http://www.fileden.com/files/2006/11/28/434089/93%20Ford.jpg" title="93 Ford.jpg"> 93 Ford.jpg </a> <br /><a href="http://www.fileden.com">Free file hosting from File Den</a>
  #25 (permalink)
Old 05-19-2008, 01:19 PM
cgraham cgraham is offline
Looks nice!
  #26 (permalink)
Old 05-19-2008, 07:26 PM
<img src="http://www.fileden.com/files/2006/11/28/434089/93%20Ford.jpg" alt="93 Ford.jpg" />
How about that, can you see it now?
So can anyone tell me how to set a new TPS sensor? Anyone?
-Chad
  #27 (permalink)
Old 05-19-2008, 07:32 PM
rankroddin250 rankroddin250 is offline
DANK! DANK!
if your overdrive light is blinking it has an electrical code. if you have the codes pulled you should be able to find out whats wrong with it.
as far as making it scream put dual straight pipes on it, make an open element air cleaner for it and turn the injector pump up.
  #28 (permalink)
Old 05-19-2008, 08:29 PM
Can they scan a 93 at a like autozone or something?
  #29 (permalink)
Old 05-19-2008, 08:32 PM
DANK! DANK!
im not sure if they can do the older trucks. I know the powerstrokes cant be. even if you gota pay some one a hundred bux to pull the codes at the dealership it should be worth it. that way you dont end up wasting a bunch of money throwing a bunch of parts at it.
  #30 (permalink)
Old 05-20-2008, 05:55 PM
2000blackbeauty 2000blackbeauty is offline
Originally Posted by HappeetxnR.N. View Post
From what I have read, if it is a speed sensor it tends to be the one in the rear end that goes bad. If I am wrong someone will correct me.
Craig
Correct, but a rear end speed sensor would also affect the speedo. It wouldnt register speed. Since your tach isnt working I would look at the tach pickup thats on top of the top timing gear cover (behind the oil fill location.) I've never owned an IDI automatic but since that tranny is electronic it would want RPM input to work properly i'd imagine.
About your glow plugs - unless its been grossly hacked into wiring oblivion, you might get away with just putting a glow plug controller on it and making it work properly. Unfortunatley, when they put a push button in it, they probably didnt switch the plugs out to 12v units... it takes them longer to heat up but they wont burn out...you put too much 12v to the OE 6v resistance plugs and they will mushroom the tips/blow the tips off if someone holds the button too long. I'd get a controller and new original glow plugs...be VERY careful taking the old plugs out as they will be sooted/possibly expanded into the holes and you can break them off and drop the tip into the combustion chamber....and let me tell you, that can turn into a bad scene real quick. Good luck.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
