| 7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines. |
how to bleed a fuel line
1992 f250 non turbo.just put a new fuel line in(fuel pump to fuel tank) and want to know how to bleed the air out of the fuel line.dont want to take the starter out again.
jus bleed the lines at the injectors while runnig or starting loosen the nut then tighten it wen fuel starts spurtin
Do you do the same for a 1999?
Well on a 99 you dont have the fuel injector lines exposed, there is no nut on each injector to loosen up to bleed. Its a whole different animal.
No it is much easier. All you do is run the pump with a few cycles of the key for a superduty. You can also open the filter drain and cycle key untill you get fuel and than close valve and cycle key a few times and fire.
I may have a different problem. I did a stupid thing and almost ran it out of fuel. I coasted into the station coughing and sputtering but it didn't die. I filled up and then left about 5 miles later it started running funny and then it would idle way down and then die. I can drive it and sometimes its fine and other times it wants to die. I put on 20 miles with out a prblem then I dorve it a few days later 5 miles and it kills but then fires right up. I have changed the fuel filter and that did not fix the problem wishful thinking I guess. I pulled the codes and it comes up low fuel pressure. Does any one have any ideas?
how long does it usually take to get the fuel through the lines to the filter?
Sounds like you picked up some crud on the tank pump screen
so there is a pump in the tank? i thought there is only the lift pump and the injector pump?
No there is no pump in the tank...but there is a screen up on the pickup tube.
