| 7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines. |
Friend's new 91 Ford
A friend of mine just showed up with a 91 diesel F350 crew cab srw auto 4x4 with some Banks stuff on it. What can you guys tell me about it for his info.
Thanks in advance |
what banks stuff does it have on it??
I was told that his 91 has
a Banks turbo with no waste gate 3" down pipe with a 4" exhaust system Muffler delete Hypermax inter cooler air intake below the windshield on the cowling. It has a throttle position sensor on the pump (????) He has some concerns, they are At wide open throttle he still has no smoke. He says that it'll on boost 6 psi under any condition and it drops off quickly (I told him that sounds like an air leak) EGTs are never more than 600* Ideas, comments, suggestions please and Thanks |
In hopes of more information. He's a recovering Cheby man |
he will have to turn the mechanical injector pump up to get more smoke/power. since those trucks where designed to run with out a turbo the after maket ones are set up to give very little boost he may see a little more lbs of boost once he get that baby burning a little fuel.
heres a step by step link I found. How to turn up fuel on 6.9/7.3 IDI - The Diesel Garage Forums GET ER DONE! |
sounds like air leak on the boost.on my old truck i ran 12 pounds of boost then my buddy messed around with it a bit and got about 22 and what a differense.but good luck fixing it.
might also check for exhaust leaks that will cut your boost numbers down real quick.
