Idi performance parts? - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #1 of 6 Old 04-11-2013, 07:22 AM Thread Starter
Question Idi performance parts?
I was wondering where I can go to get performance parts like exhaust, gaskets builds. Thanks!
Slcjordan is offline
post #2 of 6 Old 04-11-2013, 12:28 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Summit racing, amazon, rosewooddieselshop has bb code injectors, and eBay, will have those things too, but a lot of diesel shops should have upgraded pumps or access to them, as well as turbo kits from banks and ats
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 6 Old 04-11-2013, 04:48 PM Thread Starter
I've got an ats on there but I haven't been able to find any down pipes? Thanks ill be sure to check those places out!
post #4 of 6 Old 04-11-2013, 05:50 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
down pipe or up pipes?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 6 Old 04-11-2013, 09:30 PM Thread Starter
Down pipe. Would you know what else I could do to add performance without building the engine? I've just got an ats and I think after market injection pump which I turned up a little
post #6 of 6 Old 05-06-2013, 09:13 AM
If you have an ATS 093 turbo, Banks makes a replacement downpipe. Part # is 52103. Summit Racing has it but you'll get it quicker by calling Banks and ordering it directly from them. It's about 120 bucks shipped. It's a metric crap ton better than the factory crushed downpipe. As far as other mods, there's not a whole lot for these old engines. A good free flowing exhaust, good cold air intake, injector pump working properly and turned up a couple flats, and injectors that are working properly. You can also disable the wastgate on your turbo by unplugging and capping the line that runs to the wastegate actuator. This will enable you to create more boost by not letting the wastegate open. If your gonna turn the pump up make sure you have a pyrometer so you can monitor exhaust temps. Also make sure you don't have any pre-turbo exhaust leaks as these leaks will rob your turbo of boost.
LSOSGT1109 is offline
