IDI Turbo or not - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
Old 01-30-2008, 08:14 PM
IDI Turbo or not
First of all, I'm a newbie. I have a 1994 E350 bus. I know the DI Turbo came out in late 94. Was there an IDI Turbo that preceded the DI and if so, what's the easiest way to determine if I have a non-turbo, IDI Turbo or a DI Turbo. The Ford book that came with it says it's a Powerstroke Turbo but I sure don't see anything turbo-like. I've attached a picture under the inside engine cover (doghouse?).
Thanks
Old 01-30-2008, 08:24 PM
Electrical Ogre
your picture is a IDI non turbo. I'm not sure if the E series had the turbo mounted in a different place due to space issues though. If your exhaust manifolds go straight to the exhaust system, then there is no turbo. Hope this helps
Old 01-30-2008, 08:37 PM
For sure that is an IDI non turbo 7.3, I can see where the air filter sits( I hope it was you that took it off before the pic. because it is missing). I don't think Ford put the IDI turbo in the vans, just went straight to the DI.
Thanks for the reply
Exactly how big is a turbo and what does it look like. I guess the key is the exhaust manifold. If it comes right off the engine and is a straight pipe out the back, there's no turbo, right?
Old 01-30-2008, 08:39 PM
BTW, I did take the air cleaner off. Thanks.
Old 01-31-2008, 01:27 PM
correct! If theres a turbo, the exhaust from the manifold will run through the turbo. Turbos look like a rusty horn where the exhaust will go in and a clean aluminum horn next to it where filtered air comes from the air cleaner.
Old 01-03-2009, 05:40 PM
The Screwy HEUI
I know this thread is crazy old.....but I never get to use this pic. daveclow: this is what a turbo looks like.
