White Smoke ? - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #1 of 14 Old 01-29-2008, 05:20 AM Thread Starter
MSC
Question White Smoke ?
when i bought my 93- F350 -7.3 IDI it didn,t smoke at all ( has a rebuilt engine with 100,000 miles ) but lately i have noticed this white smoke when i start it cold, smokes for about a minute or so then it clears up, no smoke once it's warmed up. I have been adding 2 stroke outboard motor oil to the fuel lately & wonder if this could be what I;m seeing?
MSC is offline
post #2 of 14 Old 01-29-2008, 05:33 AM
me to i have a 03 6.0 and when i start it when its cold after sittin for a day or so alot of white smoke at first then nothin is this normal or do i have a problem --plz help befor i call the dealership-i put in the cetane boost -- thanks guys
rageingbull is offline
post #3 of 14 Old 01-29-2008, 06:36 AM
powerstrokes only's Avatar
Every diesel I have ever owned smokes white when it is cold outside after I first start them. It is perfectly normal in cold weather, now if it keeps smoking white all day at idle I would wonder if there was a problem. Your trucks sound perfectly normal to me especially if it quits after it warms up, don't worry!!! They will smoke less if you plug them in at night.
Fletcher
'90 F250 Supercab IDI 7.3
Banks Sidewinder Turbo
4'' straight pipe
116,000 miles
'94 F250 single cab IDI Factory Turbo 7.3
3'' banks down pipe
Banks pyrometer
3 1/2'' straight pipe
K&N Air filter
Hypermax air intake
Hydrogen Generator
Pump turned up
Timing advanced
315,000 miles!
'89 F250 4x4 supercab 7.3 IDI
4'' exhaust
pump turned way up!!!
297,000 miles
powerstrokes only is offline
post #4 of 14 Old 01-29-2008, 08:41 AM
thanks guy i am a rookie at diesel although i have built many off road gassers i am blown away at the diesel performance thanks again
post #5 of 14 Old 01-29-2008, 08:58 AM
DKR
<--Pro Cooler Racer
DKR's Avatar
Even my 07 the one night I forgot to plug in it almost smoked out my street!
Eric
2007 F250 6.0l King Ranch CC LB
Sponsored by Innovative Diesel Performance
SCT XCal2 w/ Custom Files & FICM tuning
DashDAQ Series II; ARP Headstuds; AFE Stage 2 XP Intake w/ Proguard 7
Industrial Injection 190cc injectors; FASS 150/180; ITP Regulated Return
'03 Turbo Swap; Zex N2O Dry Shot; CFM Smallmouth Intake Elbow
Zoodad w/ Predator Screen; MBRP 4" Cool Duals Straight Piped
EGR Delete w/ full manifold; Coolant Bypass Filter; Train Horns
Eclipse AVN62D; High Idle Mod; BFG ATs 285-65/20s
Truck- 12.51sec @ 108mph @ ~7700lbs (1/4 mi)
Cooler- 39.93sec @ 12.12mph @ ~180lbs (1/8 mi)
Email:
DKR is offline
post #6 of 14 Old 01-29-2008, 09:16 AM
Desert Shield/Storm Vet
vitalidle's Avatar
Yeah its just unburnt fuel until you engine warms up a bit. If you tune up the truck it will smoke more then if it has stock tuning
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #7 of 14 Old 01-29-2008, 04:40 PM
No problem!! Diesels are pretty cool and the performance they can put out is pretty incredible. I have never owned a gas powered truck, so I don't really know anything but diesels. You can learn an incredible amount on this forum, I learn something every time I log on! Good luck, let me know if I can ever help you!
Fletcher
4'' straight pipe
116,000 miles
3'' banks down pipe
Banks pyrometer
K&N Air filter
Hypermax air intake
Hydrogen Generator
Pump turned up
Timing advanced
315,000 miles!
4'' exhaust
297,000 miles
post #8 of 14 Old 02-06-2008, 04:35 PM
Beg to differ - if it's cold out it's not smoke, it's condensing water vapor. If it's white smoke in warm weather, you have a problem - that's coolant burning off, leaking head gasket, cracked liner, something like that......sorry
spburns is offline
post #9 of 14 Old 02-06-2008, 04:40 PM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 3 Post(s)
a diesel will blow white smoke from fuel on a cold morning , you are right it will have condensation also, but not as soon as engine starts only after heat start getting into exhaust
ITS STOCK
SCUFFY828 is offline
post #10 of 14 Old 02-06-2008, 04:44 PM
craig long's Avatar
mine never blows white smoke, but i have heard that it can if you have leaks at the injectors. one of the o rings.
late 99 f250 7.3L 265k
4" lift, dual front shocks, adjustable air bags added to rear.
new calipers, brakes and rotors all around
isspro guages
rebuilt tranny with heavy clutches and shift kit. billet cowan converter.
finned front and rear diff. covers.
rhino liner bottom strips
cattle front bumper with 2" receiver, black steel rear bumper. 315/75/16 AT
diy intake
4" straight pipe
wastegate delete
ccv mod
foil delete
zoodad mod
craig long is offline
