1992 7.3 injection pump ? - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #1 of 7 Old 03-27-2013, 12:37 PM Thread Starter
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Do you have to have any special tools to replace the injection pump? I've found some say yes and some say no. Have a guy with 4 trucks and he has new pumps for them. Wanted me to install them but I don't know if I need anything special to do it.
dhanna6powerstroke is offline
post #2 of 7 Old 03-27-2013, 04:21 PM Thread Starter
Mod Newbie
Quoted: 20 Post(s)
post #3 of 7 Old 03-28-2013, 06:27 AM Thread Starter
Mod Newbie
Quoted: 20 Post(s)
Anyone have any ideas on this one?
post #4 of 7 Old 03-29-2013, 07:48 PM
the only problems I ran into with those pumps was getting the external nuts loose because of the limited access. also you will need a 12 point 5/16 socket and short extension to remove and reinstall the three drive bolts under the 2 bolt front cover. its not that big of a job. good luck
10redly is offline
post #5 of 7 Old 03-29-2013, 07:54 PM Thread Starter
Mod Newbie
Quoted: 20 Post(s)
So no special tools needed to time pump? Awesome! Really appreciate the reply and info.
post #6 of 7 Old 03-30-2013, 06:01 PM
to time the pump line up the dowel on the drive gear,then install the 3 bolts. then just line up the scribe lines. there is 1 on the pump and 1on the housing as you are looking at it from the top. pretty pain free job. hope this all helps. good luck
10redly is offline
post #7 of 7 Old 03-30-2013, 07:51 PM Thread Starter
Mod Newbie
Quoted: 20 Post(s)
Thanks a lot for the info.
