Some pics of my IDI and a question - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
post #1 of 10 Old 03-11-2013, 05:16 PM Thread Starter
Texas6.0's Avatar
I have owned my IDI for about two and a half years. I got it with around 170k on it and I just hit 202k. It has had the dreaded head gasket leak at the rear of the drivers side head. I run the Power Stroke oil filter and change the oil every 3,500 miles. The fuel filter is changed every other oil change. I did a radiator flush when I first got it and I run distilled water with green coolant. It also has a new water pump, coolant hoses, fan clutch, thermostat, coolant temp. sensor, and the radiator was cleaned at a radiator shop. The truck has never overheated on me. I have to add around a quart of oil about every 1,500 miles and about a quart of coolant every 2,000 miles. The truck runs great, but the rear of the drivers side head is always covered in oil and you can see green drops.... I don't tow anything but, it always has a load.
Is it okay to keep using it as long as the oil and coolant doesn't mix?
I have heard that if I reseal the top end of a high mileage engine that the rings will start to leak(blow by).
'94 F-350 CC DRW 2WD Turbo IDI 7.3
Rebuilt E4OD w/"updates" & billet Precision "RV" TC
Custom welding Bed/Lincoln Classic II
Helper Bags
3" straight pipe w/one-off 6" SS tip
K&N Air Filter
Pioneer HU/Alpine components
7 235/85-16's (spare tire holder is modded for a bigger than stock spare)
FL-1995 & new ZD9's
Next: whenever the OEM injectors go out they will get replaced with BB codes
Texas6.0 is offline
post #2 of 10 Old 03-11-2013, 05:20 PM Thread Starter
Texas6.0's Avatar
Helper Bags
K&N Air Filter
FL-1995 & new ZD9's
Texas6.0 is offline
post #3 of 10 Old 03-13-2013, 08:14 AM Thread Starter
Texas6.0's Avatar
I guess I'll join oilburners.net
Helper Bags
K&N Air Filter
FL-1995 & new ZD9's
Texas6.0 is offline
post #4 of 10 Old 03-13-2013, 08:18 AM
JJFLASH's Avatar
Quoted: 111 Post(s)
That's a pretty spanky welding truck
Is it smoking pretty bad?
And don't get pouty about not getting a lightning quick response
The polite thing to do is just bump your thread.
-JJ-
Mine - 94.5 F250 ZF5: Basics w/a few extras, DIY bumper, steps and exhaust, AFEII, D60, PMF 2.25 RSK, V-codes
Hers - 04 GM 2500 CCSB 4x4: LB7, EFI Live by KW, 2" Lift, MBRP 4" dp back
RIP 15/08/23- 98 GM 1500 ECSB 4x4: 6.5, straight pipe, K+N filter, 495km w/original pump, trans & t-case
JJFLASH is offline
post #5 of 10 Old 03-13-2013, 08:33 AM Thread Starter
Texas6.0's Avatar
Thanks. It only has some white smoke on cold start which I believe is normal. It drives great and there is no visible smoke when driving and warmed up. I periodically check the oil/coolant levels and don't have to add too much. I just want to make sure it's okay to keep using it because I want it to at least get to 300k. I have put +30k on it with the head gasket leak already and who knows when it started leaking.
Helper Bags
K&N Air Filter
FL-1995 & new ZD9's
Texas6.0 is offline
post #6 of 10 Old 03-13-2013, 08:44 AM
JJFLASH's Avatar
Quoted: 111 Post(s)
My opinion? No. Get it fixed (or fix it yourself) while it's still a relatively minor problem.
-JJ-
JJFLASH is offline
post #7 of 10 Old 03-15-2013, 05:08 PM Thread Starter
Texas6.0's Avatar
Thanks.
Anybody else have any say on this?
Any IDI owners/experts?
Helper Bags
K&N Air Filter
FL-1995 & new ZD9's
Texas6.0 is offline
post #8 of 10 Old 03-15-2013, 05:45 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I'm no expert but my idi had a good loss of power, and blew tons of white smoke when the head gasket started to go I guess it finished, but I ended up selling it to another guy to fix, I would go ahead and fix the problem before it gets much worse. Beautiful rig ya got there btw, what conversion package is it?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #9 of 10 Old 03-15-2013, 07:15 PM Thread Starter
Texas6.0's Avatar
Thanks, it is a Centaurus conversion and it still turns a lot of heads. It had running boards and all kinds of other crap I took of when I first got it.
The truck is pretty slow but I figured it was normal since these IDI's aren't known for being power houses. However it does not smoke while driving and it is very reliable, a lot more than the 6.0 it replaced.
Should I add ARP head studs when replacing the head gaskets?
Should I use stock replacement gaskets?
Helper Bags
K&N Air Filter
FL-1995 & new ZD9's
Texas6.0 is offline
post #10 of 10 Old 03-15-2013, 07:40 PM
WD40's Avatar
Quoted: 39 Post(s)
(Should I add ARP head studs when replacing the head gaskets?
Should I use stock replacement gaskets? )
Yes.
That's a very nice looking truck to be almost 20 years old, if your wanting 300.000 out of it then
I would go ahead and fix it right and you should be able to get that out of it with easy. Good luck.
Doug
2006 Ford F-350 Crew Cab Lariat 4X2 PSD 6.0 TorqShift Automatic Transmission. Upfitter Switchers Chrome Door Handles,
Oxford White with lower part being Arizona Beige Metallic.
Creative Coating Sprayed in bed liner.
20K Reese 5th wheel hitch.
Mods. 4in. Silverline stainless steel exhaust
BD Diesel XMonitor
Bama ZooDad
35 HitchHiker
Is it time to go camping?
EX-USN
Doug
WD40 is offline
