Help with balancing act.. - Ford Powerstroke Diesel Forum
7.3L IDI (Non-Powerstroke) Diesels Technical discussion of topics related to vehicles powered by the 7.3 Liter In-Direct Injection Navistar engines.
Old 12-23-2007, 08:19 AM
Cool Help with balancing act..
Happy Holidays to all... so now to the issue... I am in the process of switching out motors on my 92 f-250 with a non turbo IDI in it, had over 400,000 miles on it, so I guess its time to give it a break. My things is, I'm not sure if these motors are internally balanced or externally, since the flywheels are different on each motor and from what I gather, depending on if they are internally or externally balanced may determine which flywheel to use???????
Old 12-23-2007, 08:22 AM
ADMIN AND TECH
never heard of an externally balanced engine, you need to use the flywheel that came originally in the truck, if you are reusing the clutch thats was in it, the flywheel to me is either a dual mass or not it doesnt have anything to do with the engine being balanced
Old 12-28-2007, 09:52 PM
Smile gm 454
gm 454 big blocks are externally ballanced
Old 12-29-2007, 11:55 AM
Send a message via AIM to Bamfster
So is the 400 sbc.......
